Old 09-02-2021, 10:41 PM   #1
67RS/SSx2
Center Pod in Instrument Cluster
I see most center pods are just blank with a pattern, printed on the glass I suspect. Some center pods have the turn signal indicators in them (and very large). Others contain a tach.
What determines if that pod gets the large turn signal indicators? Is it a certain trim level?
Thanks!
1972 C20 402/TH400/3.54 Highlander
1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold)
1983 GMC Sierra Classic 2500 crew cab (sold)
1972 Chevy C10 Cheyenne Super (sold)
1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it)
67RS/SSx2 is offline   Reply With Quote
Old 09-03-2021, 01:03 AM   #2
HotWheelsFan
HotWheelsFan's Avatar
Re: Center Pod in Instrument Cluster
Turn signal indicators in the center might be for early year models? I would guess the tach would be an option rather than a trim level?
I'm sure better answers will follow...
HotWheelsFan is offline   Reply With Quote
Old 09-03-2021, 01:06 AM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have a 1967 C10 and it has the big turn signal flashers in the centre pod.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-03-2021, 01:49 AM   #4
pjmoreland
pjmoreland's Avatar
If a truck has the "AMMETER OIL GAUGE" option on the SPID, then the gauge cluster will have the four additional smaller gauge openings along the bottom, and the large center gauge opening will no longer have the turn signals and oil and "generator" warning lights. I believe certain option packages included the gauge upgrade.
pjmoreland is offline   Reply With Quote
Old 09-03-2021, 10:20 PM   #5
67RS/SSx2
Thanks. This makes sense. The truck in question (not mine) does not have the AMMETER OIL GAUGE option on the SPID so the center pod with the large turn signal indicators seems to be correct for that truck.
This seems to be a bit of an unusual combination. A high percentage of the trucks I have looked at have those gauges.
Thank again!
Old 09-03-2021, 10:44 PM   #6
pjmoreland
pjmoreland's Avatar
I am not an expert on what came as standard and optional equipment, but if you take a look at the 1972 sales brochure you will see the full gauge panel mentioned for the Cheyenne Super trim level, but not for the Cheyenne, Custom Deluxe or Custom. It is also listed as an option that could be added to any trim level, as well as a tachometer.
https://www.gmheritagecenter.com/doc...ruck-PCK-1.pdf
I have owned four 67-72 trucks over the years, and only one of them (a 72 Cheyenne Super) came from the factory with full gauges. A previous owner of my truck installed a full gauge cluster, but didn't modify the wiring harness, so it didn't work right until I made the necessary modifications.
Old 09-03-2021, 10:56 PM   #7
FirstOwner69
FirstOwner69's Avatar
I am not an expert on what came as standard and optional equipment, but if you take a look at the 1972 sales brochure you will see the full gauge panel mentioned for the Cheyenne Super trim level, but not for the Cheyenne, Custom Deluxe or Custom. It is also listed as an option that can be added to any trim level, as well as a tachometer.
My '69 CST was built with almost every option including A/C and buckets but no gauges or power brakes. Part of the deal when we bought the truck was that they'd install power brakes before delivery. Here's a pic taken in 2010 before I started the frame off rebuild. As part of the rebuild I added gauges with tach.
EDIT: Added picture of the original purchase contract showing options and the addition of power brakes.
Jim
FirstOwner69 is offline   Reply With Quote
Old 09-03-2021, 11:38 PM   #8
57taskforce
All about them K’s
57taskforce's Avatar
As said above Cheyenne super is the only trim level to have standard full gauges (tach/vac not included as standard) all others the gauge package was optional.
Jim, that’s pretty dang cool that after all these years you’ve still got all the original documentation. Not many can say they are the original owners anymore.
Tyler
Old 09-04-2021, 12:33 AM   #9
FirstOwner69
They can't say "I'm really THAT old!" either. I also have virtually every receipt as well as a log of every gallon of gas used. Probably a bit OCD though!
Jim
Old 09-04-2021, 09:37 AM   #10
palallin
Interesting that the drawing only shows the two outer gauges on the bottom. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-04-2021, 10:13 AM   #11
jumpsoffrock
And that the tach has a gauge in it. Like they intended the tach area to be the oil guage or something UNLESS you ordered a tach then they'd give you the two other spaces.
lol thought this through too much.
jumpsoffrock is offline   Reply With Quote
Old 09-04-2021, 03:23 PM   #12
BROWN 70
BROWN 70's Avatar
Hi guys, mine has a vacuum gauge installed in the center pod. it looks to be a old pontiac gauge. but it looks stock. I like it. BROWN 70
BROWN 70 is offline   Reply With Quote
