Old 09-06-2021, 02:38 PM   #1
not2oldchevy
Need help with fuel pressure
53 3100 5.3 0ut of 2003 avalanche. 50 lbs fuel pressure with 3 diffrent fpr. get lean codes lt fuel trims stay maxed out 25%. Last fpr today 5olbs goes to 40s with more throttle unhook vacuum line goes to 58 lbs .Will it hurt to plug vacuum line and run it?????
not2oldchevy is offline   Reply With Quote
Old 09-06-2021, 06:44 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Need help with fuel pressure
You gonna need more than 50psi...how do you have your fpr plumbed?
I'm assuming you have a inline pump and reg..
Or are you using a return rail?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-06-2021, 07:22 PM   #3
not2oldchevy
return rail new fuel lines pump and same part number filter for the avalanche
Old 09-06-2021, 07:38 PM   #4
mongocanfly
I'm not sure on that..
Eric (ls1nova) would probably know for sure
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-09-2021, 07:17 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Post a picture of the fuel rail. maybe a bad regulator. what fuel pump. maybe poor quality parts causing fuel pressure problem?
lean can also be air leaks. need to smoke test the intake to find whats leaking if anything is. intake can be cracked, vacuum port left unplugged pinched intake gaskets...
smoke test will find the leaks
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-17-2021, 10:07 PM   #6
truckdude239
truckdude239's Avatar
What pump are you running intank or inline what model? Return style system with for 9n fuel rial?
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 09-19-2021, 09:31 AM   #7
not2oldchevy
New factory part number pump for 2003 avalanche second one. factory inline filter. return style on 03 avalanche. 3 different fpr all show 50lbs pressure. get lean codes for both sides every 5 or 6 hundred miles. put 4000 miles on it so far. unhook fuel pressure goes to 58lbs and stays. runs ok with fpr hooked up will backfire one time when you run it wfo then let off. whole fuel system is same as factory with new 3/8 fuel line. bought whole avalanche had been flipped but I drove it into garage dont know much else to tell
Old 09-19-2021, 12:14 PM   #8
ls1nova71
ls1nova71's Avatar
Post a pic of the fuel rail, injectors and fuel pressure regulator.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-19-2021, 12:20 PM   #9
not2oldchevy
70 years old will have to find someone else do do pic it is not flex fuel and no vacuum leaks
