Old 09-07-2021, 07:49 PM   #1
rpmerf
rpmerf's Avatar
Turn signals cancels too early
70 C20. Non tilt, not telescoping column. The turn signals seem to be working as intended, but they cancel too early for my taste. I have a road near me, where the road turns left, and I need to make a right turn. With the right turn signal on, the wheel only needs to turn about 1/8 turn to the left to click off the turn signal. I have to manually hold it while it is constantly trying to click off. I would like it to click off at closer to 1/4 to 1/2 turn.
Has anyone tried a replacement cam, or modifying the existing cam? The cam in my truck has 4 nubs on it. Looking at it installed, they are at about 2:00, 4:00, 7:30, and 10:30. The one that is really bugging me, is the nub at 2:00. I've been poking around online and see a bunch of these cams only have nubs at like 8:00 and 10:00. I'd really rather not modify my current cam, and I know that if I get a replacement, it will need to fit into the bearing like the current one does.
Thank you
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 09-07-2021, 07:53 PM   #2
Davidf
Re: Turn signals cancels too early
If it only cancels prematurely in one direction then that would indicate your wheel is not centered. Center the wheel. Otherwise, you will need to find a different cam/horn ring or mod the one you have.
Davidf is offline   Reply With Quote
Old 09-07-2021, 08:08 PM   #3
rpmerf
rpmerf's Avatar
It does do it both ways. I spent a bit of time looking at how it all lines up and when what hits where. I just notice it more on the one side because of a road on the way home.
I saw LMC has the stock cam for like $12, so I bought one. When I get it, I'll try cutting off the nubs at 2:00 and 4:00 and see if that gets me the results I'm looking for.
1997 GMC Suburban
Old 09-08-2021, 07:00 AM   #4
BigBird05
Almost all of the cams from that vintage will fit your column. The biggest difference is the length of the horn projection. It is a different length for different steering wheels.
BigBird05 is offline   Reply With Quote
Old 09-08-2021, 10:05 AM   #5
rpmerf
rpmerf's Avatar
The main difference I saw was that the one I have is beveled at the edge. I believe it fits into the top bearing. Most of the ones I saw scrolling through Summit Racing have a flat bottom. These look like the one used on tilt columns with a spring.
I'll see how it goes modifying a stock cam first. If that isn't good enough, I'll look for another cam with a beveled edge.
1997 GMC Suburban
Old 09-08-2021, 10:15 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
Sub’d
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-08-2021, 10:37 PM   #7
Warrens69GMC
Warrens69GMC's Avatar
On my 1978, I pushed the pin for the cloverleaf, and rotated in the direction needed.
Worked like a charm.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-08-2021, 10:22 AM   #8
rpmerf
rpmerf's Avatar
I bought a replacement cam from LMC and cut the 2 back tabs off. It is a lot better now. I can turn on the right turn signal, and steer to the left without it cancelling. The 2 remaining cams do seem to be spaced a bit wide. It will cancel when I turn on the left turn signal, then get in a left turn lane. Other ones I saw online has those 2 cams close together. I'm wondering if I want to play with it a bit more. Cut off the 2 there and epoxy on a piece or 2 of rod.
1997 GMC Suburban
