Old 09-15-2021, 06:25 PM   #1
ellisjay2
Air breather to fit Holley 4150??
Which inexpensive air cleaner will fit Holley 4150 carb? The zone has the basic edelbrock triangular metal hole filter around $30....If it'll fit I just grab it..not sure??? Or one the basic round drop base filters...Name:  20210912_182548.jpg
: Eli540
86 gmc 2500 longbed Carb 5.7, rwd,
400 tranny.
ellisjay2 is offline   Reply With Quote
Old 09-15-2021, 07:53 PM   #2
geezer#99
geezer#99's Avatar
Re: Air breather to fit Holley 4150??
You might not have room for a drop base cleaner. You could have interference with the distributor.
A generic chrome air cleaner is all you need.
If you like engine fires then buy the triangle edelbrock one.
They are known to light on fire if you get a back fire.
One like this would work.
https://www.summitracing.com/parts/p...yABEgJ29vD_BwE
Old 09-15-2021, 09:13 PM   #3
Gregski
Gregski's Avatar
just don't fall for the oil cleaned K&N nonsense, get the tallest one you can fit under the hood from Summit
Gregski is offline   Reply With Quote
Old 09-15-2021, 10:00 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
Edelbrock 10" 1208 (chrome) or 1203 (black)
Discard the original filter (if you wish) and use a CA160, CA192, CA3588 depending on height desired
Old 09-16-2021, 12:00 AM   #5
farmall
farmall's Avatar
I used the 60s 70s Chevy HP open drop housing. It fits fine with HEI and uses Corvette PCV and breather set up.
NAPA 6096 is a nice 14" X 4" filter with a foam wrap. WIX #46096.
http://67-72chevytrucks.com/vboard/s...d.php?t=643974
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 09-16-2021, 07:37 AM   #6
I used a Speedway Motors 10" Inch Low Profile Small Chrome Air Cleaner.
https://www.ebay.com/itm/13337415515...4664ddfa0827c0
