Old 09-22-2021, 10:03 PM   #1
65chevysub
65chevysub's Avatar
Sticky accelerator cable.
I replaced my accelerator cable today, and it takes some heavy pressure to make it work. I put some oil down the housing before installing it, but is there something else to make it work smoother? I thought maybe the connection at the carb was too tight, but theres free play there.
65chevysub is offline   Reply With Quote
Old 09-22-2021, 11:02 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Sticky accelerator cable.
spring may help how tight it is. The spring can go on the top forward if you do not have the right tension, or can go on the rear to the bottom like factory. The tighter the spring harder the tension is the harder the peddle will feel. So it how much peddle feel you like. But very soft will be harder to keep RPM's and foot smooth.
It's hard to see your setup in the pic on the Carter carb with a E.B. stamping. I all ways liked factory carbs or Holley or Holley style carbs.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-23-2021, 09:07 AM   #3
blazer2007
Mine did the same, I replaced it and was fine . Not too expensive. Maybe a small fray in the cable
blazer2007 is offline   Reply With Quote
Old 09-23-2021, 09:48 AM   #4
Rickysnickers
Rickysnickers's Avatar
Straightened your photo
Old 09-23-2021, 09:55 AM   #5
geezer#99
geezer#99's Avatar
Likely help a bunch by moving the attachment point of the cable on the carb up higher on the bracket.
Present location is too close to the throttle shaft centreline.
Old 09-23-2021, 05:53 PM   #6
65chevysub
65chevysub's Avatar
It's a brand new cable. Just put it on yesterday. I checked the movement before I put it on, and theres no binding. It does have the arc after it clips into the bracket then goes into the firewall
Old 09-23-2021, 05:55 PM   #7
65chevysub
65chevysub's Avatar
Thanks. Dont know why it turns my images sideways. It's right side up on my phone
Old 09-23-2021, 06:04 PM   #8
65chevysub
65chevysub's Avatar
Where can I move it to? I'm not seeing anywhere else to put the cable. Can you highlight where I can put it?
Sorry about the pic. Must be my phone turning them sideways
Old 09-23-2021, 06:06 PM   #9
Dead Parrot
From the pic, it looks like the flare at the rear of the plastic tube might be binding on the metal bracket for the trans shift cable. If your trans doesn't need that shift cable, might bend that part of the bracket a bit to give the throttle cable more clearance.
My Eddy 1405 has the throttle cable in the same hole as yours but due to a 1" spacer, the trans shift cable is on a separate bracket so I don't have any bracket/throttle cable interference. The return springs run from the higher hole on the carb to a homemade attachment point forward of the carb.
Edit: looks like your return springs are just like mine based on your last pic.
Dead Parrot is offline   Reply With Quote
Old 09-23-2021, 06:13 PM   #10
65chevysub
65chevysub's Avatar
Thanks. I will look at that when the engine cools off. I just stretched the spring a little bit, and it's working better and not binding like it was
Old 09-23-2021, 06:49 PM   #11
geezer#99
geezer#99's Avatar
Look for or make a simple bracket like this that lets you use that big hole.
https://www.jegs.com/i/Edelbrock/350/1493/10002/-1
Old 09-23-2021, 08:02 PM   #12
Rickysnickers
Again
Old 09-23-2021, 08:07 PM   #13
65chevysub
65chevysub's Avatar
Again
Thanks....again. will use the desktop next time
Old 09-23-2021, 08:13 PM   #14
Rickysnickers
No problem. When you have a chance, take a look at this thread for posting your photos. Hope you get your issue fixed.
https://67-72chevytrucks.com/vboard/...d.php?t=818026
Old 09-23-2021, 11:07 PM   #15
Pontiac1976
Ok now that I can see your spring, how much tension on the spring you can buy help red spring pack for carbs play with some to get the right peddle feel. You stretch the tight strong springs bend them like the factory till it to your liking.
I guessing the factory one may be a little tight pulling to much on your gas peddle for you foot making it hard to press. So lighter tension spring spread the spring apart a little lighten the tension.
I think this will help.
Old 09-23-2021, 11:12 PM   #16
Pontiac1976
Oh and the two springs where hook to the linkage turn the hooks out from the carb so they do not get caught on the rod linkage.
Old 09-24-2021, 11:50 AM   #17
truckin 79
You could try just one spring on carb as long as it pulls cable all the way back on idle stop screw. You could also try putting spring between the small hole in carb linkage and just below cable in linkage.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 09-24-2021, 04:35 PM   #18
65chevysub
65chevysub's Avatar
I stretched out the spring and it works perfect now. Thanks everyone for your help. I appreciate it.
