Old 09-28-2021, 08:47 PM   #1
4u2nv
drivers side window movement
All of a sudden the drivers side window on my 87 k10 wants to slide back and forth , roll it down and it flops out of the felt and then to roll it back up you have to steer it into the felt , what makes it do this ???
Took the door panel off and looked but I don't know what I'm looking for , any help on this would be great.
4u2nv is offline   Reply With Quote
Old 09-28-2021, 09:09 PM   #2
blazer2007
Re: drivers side window movement
Mine was the rear upright rail , it is tack welded to a support rail and the tack weld has broke. I,m sorta sure which rail ,but I do know one of the supporting rails has failed. Can take it apart and tack it again. To much slamming the door with bad felts and such I,m guessing
blazer2007 is offline   Reply With Quote
Old 09-28-2021, 09:18 PM   #3
4u2nv
That I did see and all seemed good and firm , thanks though
Old 09-28-2021, 11:04 PM   #4
Pontiac1976
Pontiac1976's Avatar
Check you white roller bushing, that there in the tracks or not broken( REG.on the linkage) if the panel off roll up & down as you check the REG. to see if there is a miss hap it or other parts. If you have to check your good window see what different.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-29-2021, 08:54 AM   #5
TKCR
TKCR's Avatar
I agree with Pontiac, it’s probably broken wheels. If it’s not that, it’s definitely something in there. Look also at you door sashes, make sure they are tight.
