Old 10-04-2021, 03:04 PM   #26
MJN
MJN's Avatar
Re: Any truck detectives here? Hauled home another.
Right front fender is 67 with the hood being 69-72. Box is 68 or later. And I'm not sure but isn't that a large letter 70 and later tailgate?
And that 292 looks odd.
She was a stump puller for sure from the factory. (At least the SPID was) 292 with a 4 speed and a posi 4.57 rear end.
Looks like it had a NP435 trans instead of a Muncie. Maybe it might have been a snowplow rig at one time- sure beefed up the front springs too.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-04-2021, 04:38 PM   #27
'68OrangeSunshine
'68OrangeSunshine's Avatar
I see the SPID quotes L25 292CuIn L6, but that's a small block Chevy V8 with rams' horn exhausts. Oil pan is painted red which is proper GMC engine color.
'68OrangeSunshine is online now   Reply With Quote
Old 10-04-2021, 09:24 PM   #28
dagnabbitt
dagnabbitt's Avatar
Originally Posted by Joesjunk View Post
That front rally wheel is on backwards lol
Upside down, too.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-04-2021, 10:35 PM   #29
too much stuff
Roadtrip!
too much stuff's Avatar
All he had that held air were a set of 88 and up wheels. The fronts had to be put on backwards to clear. Notice it still has a trim ring on the inside. I had less than an inch between the wheel wells on my trailer to load.
I am enjoying all of the responses here. You all have picked it apart about the same as i have.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-04-2021, 11:13 PM   #30
jumpsoffrock
I wonder if in about 1980-1990 A gentleman and his 15 year old son went to the local wreckers and the father told him, "son, you can make any car you want..."
jumpsoffrock is offline   Reply With Quote
Old 10-05-2021, 05:43 AM   #31
I agree on the body swap, '67 cab on '72 frame. That passenger fender had the side marker hole filled. Many odd parts are swapped, such as the instrument panel ('68)
Old 10-05-2021, 09:11 AM   #32
geunther
geunther's Avatar
Johnny Cash built this truck, took it out in his lunch box.
geunther is offline   Reply With Quote
Old 10-05-2021, 10:26 AM   #33
Steeveedee
Who Changed This?
Steeveedee's Avatar
And the title weighed 40 pounds!
~Steven
Simi Valley, CA
Old 10-05-2021, 09:02 PM   #34
68Gold/white
Man I’m glad you talked him out of those 72 parts, if you hadn’t, we all woulda thought you were coming down with either dementia or Alzheimer’s.........
68Gold/white is offline   Reply With Quote
Old 10-05-2021, 09:05 PM   #35
68Gold/white
It could be a 292..........a .060 over 283..... I own one...
Old 10-05-2021, 10:15 PM   #36
'68OrangeSunshine
Har Har Har. Good point. I've heard of Circle Track guys building a ''Cheater 292'' by over boring the F&*@ out of a 250 block.
Not sure if they use a post- '68 292 crank in that, it has 12 lobes instead of 6. Some kinda midget racing voodoo.
What I meant was that a V8 is not an RPO L25 292 L6.
[* Actually, at .030-over my 292 is really 296 CuIn, but try asking for parts for a 296. They'll wonder what dimension you just phased in from...]
Old 10-06-2021, 07:14 PM   #37
chevy71super
Is there any emergency brake mechanism in the cab? I can't see if it had the 67 under the dash pull handle or the later e-brake pedal. It also looks like the engine is set back in the 4 wheel drive position. I don't recognize the fan shroud however. My 71 and 72 K10's have a different shroud. I also can't tell if it has a long or short water pump.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
