Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-05-2021, 12:44 PM   #851
SCOTI
SCOTI's Avatar
Re: Ok Boys and Girls it's Storytime
Originally Posted by aggie91 View Post
Dang that sucks. Hopefully there is not any major damage inside.
x2. And.... How the heck did it happen?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-05-2021, 07:21 PM   #852
regan wilson
regan wilson's Avatar
I don't know guys. I wish I could question the other end of that damn bolt. I looked for that SOB and the rest of the missing pieces till I just had to give up and go home. I worked a couple of hours this afternoon and got the motor out and on the stand. I pulled the intake and the D/S system. I'll try to get it all the way down tomorrow evening.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 10-06-2021, 07:02 AM   #853
mongocanfly
mongocanfly's Avatar
dang the bad luck...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-06-2021, 08:24 PM   #854
71Dragtruck
71Dragtruck's Avatar
$hitty deal!
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 10-06-2021, 08:46 PM   #855
regan wilson
I got it down to the short block today. I don't think it's too bad. I'll report back tomorrow. The rods moved back and forth so that's good.
Old 10-09-2021, 09:35 PM   #856
regan wilson
I think I dodged a bullet. It was trying to eat the 3 and 4 main bearings. I'm going to set up an Idiot light on an oil pressure sensor. I am getting old ya know.
Old 10-13-2021, 08:51 PM   #857
litebulblsc
litebulblsc's Avatar
Maybe look into an accusump?
litebulblsc is offline   Reply With Quote
Old 10-14-2021, 07:40 AM   #858
regan wilson
It's on the shelf. I ran one for years on my wet sump. I took it off when I did the dry sump deal. I dropped a Melling pump in the pan back in 2005. The Accusump saved the mains but not the rods. It doesn't matter if you're not paying attention. Hence the idiot light. I also thought about a mechanical hand hooked to a pressure switch. No pressure? Slaps me in the head! Lol
Old 10-14-2021, 07:56 AM   #859
regan wilson
My plan was to have it out after the Fall Nationals last weekend. I met one of Slick Rick's friends about an hour from home Sunday. He delivered my heads to Rick. That saved me a day. Monday I drove the 4 hour drive to Donnel's and dropped off the short block. I haven't talked to him since. But we think all the crank needs is a polish. We have to order pistons from JE, rods from GRP, rings from Total Seal, and lifters from Crower. Some parts have been two months out and worse. I want everything together by the end of January.
Old 10-14-2021, 08:04 AM   #860
regan wilson
Old 10-14-2021, 08:05 AM   #861
regan wilson
These were the black coated King Bearings. I think I wore the black off.
Old 10-14-2021, 08:06 AM   #862
regan wilson
Old 10-18-2021, 08:36 AM   #863
regan wilson
Well I had to get motivated and get started on the idiot light. I've ordered a pressure switch and an led light. It only took 30 minutes of contortionist moves to get the light switch out. The roll cage gets in the way of whatever you try to do. Ken showed up and helped get all the gauge lines pulled through the firewall. I've been wanting to give the cluster a refresh for awhile. I've just put it off because it's such a PITA to get out.
Old 10-18-2021, 08:45 AM   #864
regan wilson
After that we were talking about Whitey. I told him it wasn't running. I've had problems where once it sat awhile it wouldn't start. I thought it was losing prime on the fuel. He asked if I had beat on the carb with a hammer? I said no. I filled the bowl with fuel and we beat on it when I started it. Tada it ran! We went for a ride and decided it was time for the muffler to come off. It leaked everywhere and sounded like it was on the verge of stopping up with all the loose pieces inside. Out came the sawzall and five minutes later it sounds like a hot rod Log Truck. It actually sounds pretty good. The carb is rich enough that it doesn't pop on deceleration.
Old 10-20-2021, 08:17 AM   #865
regan wilson
I've gotten my gauge cluster all blown apart. I've been scrubbing and sanding on everything getting ready to repaint it all.
Old 10-20-2021, 08:25 AM   #866
regan wilson
All I had time to do yesterday was get the placement I wanted for my LED warning light and drill a hole for it. I may add some more behind the fuel gage. It will be running off the key switched terminal on the fuse block. That means it also will tell me (Hey stupid! Turn the key off)
Old 10-20-2021, 08:42 PM   #867
regan wilson
I got a call from Donnel today. The good news is my crank is straight as can be. The little bit of heat shrunk the main caps on 3 and 4. So all the block needs is an align hone..
Old 10-21-2021, 07:31 AM   #868
regan wilson
I got started on painting yesterday. I's time consuming just trying to tape off all this mess. I'm going for more of an aluminum color to go with the Autometer gauges. After this color I have to go back and tape the fresh paint off to spray the black.
Old 10-22-2021, 07:30 AM   #869
regan wilson
Progress.
Old 10-22-2021, 07:34 AM   #870
regan wilson
I also made some new lenses behind the fuel gauge. The old ones were painted over. I stuck two of the LED lights in there. It's all wired together.
Old 10-22-2021, 07:38 AM   #871
regan wilson
Almost done. I have some hand lettering and touch ups to do. I also repainted the blue inside.
Tada! We have light.
Old 10-22-2021, 08:52 AM   #872
aggie91
I'm just glad to be here!
aggie91's Avatar
that turned out nice.
I'm guessing there might be a story behind the odometer reading...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-22-2021, 09:12 AM   #873
regan wilson
Thanks Karl. The Odometer hasn't worked since 82. The truck had over 100,000 miles on it then. I twisted it around to 454 20 plus years ago.
Old 10-22-2021, 09:25 AM   #874
regan wilson
I also found out yesterday per Peterson Fluid Systems. They don't do any v belt pulleys on their mandrels anymore. It seems they have had too many failures. Hmm. I'm going to have to convert my alternator over to the HTD type cogged belt like the Oil Pump.
Old 10-25-2021, 01:31 AM   #875
LT7A
Regan, thanks for all the information and history that you've posted here. I just read the whole thing and it's quite a story. I go see the NHRA Northwest Nationals when they come to town, but didn't have much of an idea of what it takes for you to run in your class before reading all of this. Great looking truck, and I hope that you get the parts that you need soon.
