Old 10-07-2021, 12:06 PM   #1
Duncan K
Positive Camber with CPP drop spindles
Anyone else end up with severe positive camber after installing a set of CPP drop spindles? I am running a 3" lowering spring as well. Even with all the shims and spacers removed I think I would still be positive on the camber.
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 10-09-2021, 06:47 PM   #2
SCOTI
SCOTI's Avatar
Re: Positive Camber with CPP drop spindles
I have CPP Modular spindles but not a stock set-up otherwise as far as the x-member.
Do you have any pics you can share? That might generate some ideas or suggestions.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-10-2022, 07:31 PM   #3
Duncan K
Getting back to this post to hopefully find a solution. I am using stock cross member and control arms. I installed CPP's 2.5" drop spindles and a 3" lowering spring. Truck is a 1966 GMC 1/2 ton. It looks like even if I removed all the shims and spacers from behind the upper control arms the arm would hit the frame before the camber would be corrected.
66 GMC 910
Old 10-10-2022, 07:52 PM   #4
Arne
Arne's Avatar
You can't measure camber until you get the weight on it. No engine/cab/etc will equal much positive camber.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 10-10-2022, 08:11 PM   #5
Duncan K
This is an old picture. The fully assembled truck still has really bad positive camber
66 GMC 910
Old 10-10-2022, 09:29 PM   #6
PGSigns
PGSigns's Avatar
What does the camber look like? Having the upper control arms on the wrong side makes everything off. From the pictures they look flipped.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-10-2022, 11:07 PM   #7
theastronaut
theastronaut's Avatar
How much camber are you talking? Use a phone app to measure down to the tenths if you don't have a digital angle finder to check with.
theastronaut is offline   Reply With Quote
Old 10-11-2022, 09:28 AM   #8
Riverstory
Riverstory's Avatar
I second what PG Sign says. I don't want to admit it, so I won't LOL but I had mine switched when I did my frame off.
Riverstory is offline   Reply With Quote
Old 10-11-2022, 09:36 AM   #9
SCOTI
SCOTI's Avatar
I know having the uppers on the wrong sides will definitely skew the Caster.
Not sure how much it would impact Camber though. Weight on the chassis will make a difference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2022, 01:57 PM   #10
Duncan K
I had a look at the assembly manual. I am pretty sure the controls arms are on the right sides. Looks like the angled side and the bump stop are to the rear. This is a photo of the passenger side
I stuck an angle gauge on the hub. It is showing 2 degrees. I am surprised it isn't more, it looks ridiculous looking at the wheel
I am going to pull all the shims and see where that gets me.
66 GMC 910
Old 10-11-2022, 02:36 PM   #11
SCOTI
SCOTI's Avatar
I was going to say remove any/all shims. Keep them tagged for the location they were pulled w/a pic for reference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
