67 drivers door
Came off a 67 custom camper. Pretty decent drivers door but has speaker cut in it. The passenger door skin has no rust, but the inside bottom is rusted out (can send pics of the passenger door to phone).
$180 for drivers door picked up and I will throw the passenger door in on the deal. May be able to meet the weekend of 10/16 headed to Indianapolis then south to Chattanooga Tenn. Or weekend of 10/23 to Joliet Ill. Thanks Russ |
Re: 67 drivers door
NEW PRICE $150 FOR THE SET
Thanks Russ |
![]() Join Date: Jun 2005
Re: 67 drivers door
Russ, is the tab that connects the inner and outer door skins still intact? Any rust holes anywhere? Would like to see some better pics of the bottom of the door (horizontal area that would be above the sill on the cab).
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#4 | |
Re: 67 drivers door
Thanks Russ |
Re: 67 drivers door
PM sent with number
Re: 67 drivers door
More pics. after I wire brushed it a bit. Looks like 1 pin hole and a dent on the underside front corner, Sent to your phone as well. pretty nice door when cleaned up.
Thanks Russ |
Re: 67 drivers door
Russ, any cracks in the hinge mounting area?
Re: 67 drivers door
Mark, not that i can find. Nice straight doors that fit well into the cab. Only major issue is the passenger side inside bottom is rotted out. None of the bottom corners are rusted through where the normally are. No crease that i can find and the hinge points fit well.
Thanks Russ |
Re: 67 drivers door
Is this weekend the only time you will be coming through Indy?
Re: 67 drivers door
For now yes, this is the only time i will be that far east.
Thanks Russ |
![]() Join Date: Dec 2013
Re: 67 drivers door
When you head south to Chattanooga are you going thru Nashville or Knoxville ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Re: 67 drivers door
Grumpy,
Going through Nashville, meeting Dwayne (getter-done) at Murfreesboro on Sunday. Thanks Russ |
#13 | |
![]() Join Date: Dec 2009
Re: 67 drivers door
Load them up Russ, Money is good
![]() Quote:
Maybe trade and barter stuff ![]()
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#14 | |
Re: 67 drivers door
#15 | |
Re: 67 drivers door
#16 |
Re: 67 drivers door
Thanks guys I will load them up, work out payment details later. Give Dwayne a chance to do his Barter thing with grumpy. LOL!
