Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-20-2004, 05:08 PM   #1
Andrew 62
Unhappy In desperate need of 62 c-10 axle
If any-one can help it may be you people. I've looked high and low for a drivers side rear axle for my 62 c-10 pick-up. Many claim to have it but fail to come up with the correct dimensions I need. If anybody can help it would be appreciated.
Andrew 62 is offline   Reply With Quote
Old 07-22-2004, 12:11 AM   #2
64fleetside
Try Tom Myers truck parts, Miami, OK (918)-542-3871
64fleetside is offline   Reply With Quote
Old 08-12-2004, 01:37 PM   #3
LeRoy
Registered truck nut
LeRoy's Avatar
What rearend is it. 12 bolt or Dana 44. Give the length and spline count also
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 08-21-2004, 10:39 AM   #4
Andrew 62
The rear-end is the Dana with the drop out third member. Spline count is 17. Length from inside surface to end of the button is 29 5/8 , or 29 9/16. the length is real close due to the axle being in two pieces. Also the button on the end is the thick button. There were 2 styles. One was about an eighth inch thick and the other around 5/16. Six lugs for the lug nuts also.
Old 09-03-2004, 08:05 AM   #5
MOTHERTRUCKERS
Do you need the small or large button? also what zipcode for shipping?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-04-2004, 05:36 PM   #6
jim walker
jim walker's Avatar
I m comfused Axle in 2 pieces? 60 - 62 should be the same (1/2 ton with removable gear carrier aka third member, pumkin) and my 61 axles are 1 piece. Never heard of a 2 piece axle. Also, are you referring to the button end as the end that accepts the c clips? Just curious...
jim walker is offline   Reply With Quote
Old 09-29-2004, 07:09 PM   #7
Andrew 62
To clear things up the axle broke into two pieces. And the button is the end that accepts the c-clips. And also I found a NOS axle at Tom Meyers. The truck is on the road and I drove it to my wedding last weekend. Of coarse I had to lay some rubber out of chuch. What other choice did I have, With everybody watching and all. Thanks 64 Fleetside for the advice.
Old 09-30-2004, 08:13 AM   #8
64fleetside
Glad to hear you're back on the road. Brian
