#26 | |
Re: Anyone use the headlight relay wire harness from LMC
1970 GMC K2500 aka MaTeR ![]() 2007 Chevy Silverado 1500HD Classic |
#27 |
Just the connectors at the headlight only
#28 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Is there a better brand/kit than LMC?
#29 |
![]() ![]() ![]() Join Date: Jan 2018
I used the United Pacific harness purchased through Summit Racing. Looked to be a quality product, and it worked great. Made my old sealed beams bright enough that I don't feel the need to upgrade any further at the moment.
Edit: Sorry, just noticed that this is for the 4 lamp one. Not sure what is out there for that, but if United Pacific makes one for that application, I wouldn't hesitate to buy a product from them again.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#30 |
Thanks, I'll check it out.
#31 | |
Moderator
![]() ![]() Join Date: Aug 2011
#32 |
The green and brown wires at the low beam triple prong plugs need to be switched to the same order as the old plug. Brown goes on top and green on the side. Carefully pry them out with a small flat head screwdriver and switch them on each plug. Thanks to this thread I figured it out.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
#33 |
![]() Join Date: Mar 2011
In my opinion, anything BUT LMC would be better. I bought my relay kit from AAW. It's just the 2 headlight system. I have quit buying from LMC. I had a couple of situations before I learned my lesson. It seems they have no quality control.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
