Old 10-24-2021, 05:30 PM   #1
jmking9
jmking9's Avatar
Blazer body mount question
I have a 72 blazer 4wd that has has some interesting mods from the PO. Can anyone tell me if these look like stock bushings? If I remove the aluminum spacers, will I be at stock height? This is my experience with a blazer, so I'm not sure what the stock ones would have looked like.
Edit: I apologize for the sideways pics
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 10-24-2021, 06:40 PM   #2
zammer
Addicted user
zammer's Avatar
Re: Blazer body mount question
Hi those do look like stock style bushings under the spacers, they could be the polyurethane ones instead of stock rubber. I personally would not reuse the bushings as some might have had more load on them than others that squished them down and that may require more shims etc to level properly. It looks like the previous owner did a body lift.
If you were going to go through all the work of getting rid of the spacers new bushings would make sense to do at same time
zammer is offline   Reply With Quote
Old 10-24-2021, 06:46 PM   #3
zammer
Addicted user
zammer's Avatar
I think those are the polyurethane ones
Check out this thread it has some pointers and diagrams
http://67-72chevytrucks.com/vboard/s...d.php?t=340108
1972 2wd Blazer - 95% completed
2015 Silverado 1500 4wd -z
2008 AERO 9-7X (TBSS cousin) LS2
1970 Jimmy 4wd - future project
Old 10-24-2021, 07:22 PM   #4
truckster
truckster's Avatar
I replaced my body mount bushings with rubber ones from Wes at Classic Heartbeat (he's a board member). The parts were first rate and the service was excellent.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-24-2021, 08:13 PM   #5
jmking9
jmking9's Avatar
Thanks for the replies! I'm certain these are rubber and not polyurethane. I'm just trying to get it back to stock height. I want to get rid of the body lift, as well as the suspension lift that is waaayyy too much for my taste. I will look into the set from Classic Heartbeat.
1970 SWB Build
Old 10-24-2021, 09:03 PM   #6
litebulblsc
litebulblsc's Avatar
That leaf spring mount is scary. I would worry more about that then the body bushings
litebulblsc is offline   Reply With Quote
Old 10-24-2021, 10:35 PM   #7
jmking9
jmking9's Avatar
Trust me, I know. There are a lot of things under there that are that scary or worse. I was being nice when I said the PO's mods were "interesting" That's why it's all coming off and going back to stock. And don't worry, I have not, and will not drive it like it is currently
1970 SWB Build
