Old 10-30-2021, 10:22 AM   #1
Android04
Android04's Avatar
14 Bolt Rear End questions
So I'm currently in the market for a SRW 14Bolt Rear End and I've read a few forums and Pirate 4X4 sites and just wanted to get some input.
I'm looking to purchase a 14bolt SRW out of a 88-98 OBS, and was curious if I would have any issues with it fitting a 1985 C30 or should I continue my hunt for a 73-87 SRW?
I'm sure this is out there, but I've not had any luck so far. Thanks everyone
Android04 is offline   Reply With Quote
Old 10-30-2021, 10:39 AM   #2
kwmech
Re: 14 Bolt Rear End questions
What is in the 85 now
Old 10-31-2021, 09:29 AM   #3
ky-donzi
You will need to verify what I’m typing
But
I know there are different widths of these axles depending on whether the donor truck was a dually, a fleet side, or a cab chassis.
Also I’m almost positive the spring perches were further outbound on the 88-99 generation trucks. The frames were wider
So with that said I think there are about 5 different axles that at first glance look the same
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
Old 10-31-2021, 09:59 AM   #4
ACS
The spring perches are different spacing between square body and OBS. Not a big deal if you can weld, but not bolt in.
ACS is offline   Reply With Quote
Old 11-01-2021, 05:55 PM   #5
Ziegelsteinfaust
The only reason I would go with the later axle would be to widen my rear end track width.
It will need new spring mounts, and the shock mounts relocated.
I have done it with the 14 bolt SF, and it takes a bit of work. To get it to line up, but I was happy with the results. Prefect rear stance while being able to rotate tires all with out spacers.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-03-2021, 02:10 PM   #6
Android04
Android04's Avatar
Thanks everyone. I found a 73-87 SRW 14bolt locally
Old 11-03-2021, 06:22 PM   #7
sweetk30
sweetk30's Avatar
Just a heads up .
2wd and 4wd have different shock mount positions.
And there is 3/4ton will not bolt in to 1ton as they have the wider spring spacing .
There is 3/4 ton crew cab 2wd that is 1ton under its body .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-03-2021, 08:59 PM   #8
Mike C
Mike C's Avatar
To clarify, one ton trucks (or 30 series) have spring perches at 40.5” while 3/4” ton trucks have spring spacing at 42.5”
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-25-2021, 12:11 PM   #9
Desert1957
Desert1957's Avatar
Is this measurement center to center?
Desert
Desert1957 is offline   Reply With Quote
