Old 10-28-2021, 11:41 AM   #1
lts70
1970 Daily Driver
lts70's Avatar
16” Tires on C20
Picked up a project truck. Replaced the missing carburetor and with a little time the 402 is running pretty dang good. Now I need to get some shoes that don’t look like they’ll explode just by looking at them. The truck has 235 85 R16 on it right now but I was thinking of going to a 265 75R 16 to fill out the wheel wells a little more. Looking for advice.
looking at getting these tires
https://www.ebay.com/itm/39360416413...MAAOSwJPphVfkZ
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 10-28-2021, 11:51 AM   #2
NorCalC20LWB
Re: 16” Tires on C20
I'm very happy with the 265/75/16, as you say it fills out the wheel well nicely on a 3/4 ton.
NorCalC20LWB is offline   Reply With Quote
Old 10-28-2021, 12:16 PM   #3
kwmech
I've got 285s on my 68 with an alum rim
Old 10-28-2021, 12:20 PM   #4
lts70
1970 Daily Driver
lts70's Avatar
Your truck looks awesome! Did you mount them on the Chevy 6" rim or find a set of the f*rd 7" rims?
Any pictures of your truck with the 285s?
Old 10-28-2021, 12:27 PM   #5
Joesjunk
Joesjunk's Avatar
You might check those eBay tires, I don’t think they are LT rated, just P rated. I’m sure they are offered both ways.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 10-28-2021, 12:33 PM   #6
kwmech
here ya go
Old 10-28-2021, 01:03 PM   #7
NorCalC20LWB
Thanks, I did try to find some used Ford rims, I lived in the Sacramento, CA area back then. All the local salvage yards only had junk rims, so I bought online from this company, 7x16.
https://www.roadreadywheels.com/prod...teel-wheel-rim
Old 10-28-2021, 01:26 PM   #8
72c20customcamper
72c20customcamper's Avatar
Used the same wheel on my 72 man price has gone up in two years ,I paid $70 apiece . Firestones 265/75R16 E rating on my 20don’t load the bed but I tow my 68 to shows .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-28-2021, 05:54 PM   #9
lts70
1970 Daily Driver
lts70's Avatar
Has any one tried the 265 75R 16 on a 6" rim?
Old 10-29-2021, 09:44 PM   #10
steveimpala
What brand tire are those ? I need to replace mine on my '69 C20... Thanks
steveimpala is offline   Reply With Quote
Old 10-30-2021, 11:14 AM   #11
NorCalC20LWB
Wild Country Trail 4SX from Les Schwab
Old 10-30-2021, 11:46 AM   #12
steveimpala
Thanks !
Old 10-30-2021, 05:18 PM   #13
steveimpala
Here is my '69 C20... it has 285/75/16 tires, they need to be replace, looking at the 265/75/16....
Old 10-31-2021, 05:53 AM   #14
Killer Bee
Killer Bee's Avatar
these were the closest metric size LT tires to the originals on these longhorns..
LT245/75R16 BFG A/T KO2 tires on Chevy 6.5" wheels
LT245/75R16 Goodyear Wrangler tires on ford 7" wheels
Old 10-31-2021, 08:12 PM   #15
Mike C
Mike C's Avatar
235 85 16 and 265 75 16 are virtually the same height just different width. Either is a good choice, but I prefer the wider tire look. If you plan on running a 6” rim I would stay with the 235 although lots of 265 installed on the 2000-2008 GM 6.5” rims. I ran 265 75 16 0n my ‘70 C2500 on Alcoa super single forged wheels and it looked fantastic. The math, if you are interested:
265 is the section width in millimeters. There are 25.4 mm per inch. 265/25.4= 10.43 inches wide. The profile is 75% of the section width: 10.43 x 75=7.825” sidewall height. Times two for the bottom of the tire and top of the tire = 15.64 inches high. Added to the 16” rim diameter you have a tire 31.64” tall and 10.43 inches wide.
235 85 16 tire is 9.25” section width and 31.72” tall.
245 75 16 is 9.64” wide and 30.4” tall
285 75 16 is 11.2” wide and 32.8” tall.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-01-2021, 12:44 AM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
All true, and a great explanation of what the tire sizes mean. If I may, I would like to add that the measurements can be somewhat nominal. There are sometimes slight variations in actual dimensions from one brand to another. This is usually insignificant unless someone is super particular about tire size or is mixing brands.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-09-2021, 12:05 PM   #17
lts70
1970 Daily Driver
lts70's Avatar
Found these on craigslist. Seems like a good deal.
Can you run beauty rings and the stock dog dishes at the same time?
Old 11-10-2021, 10:56 AM   #18
72c20customcamper
Stock dog dish wont work on those no nips. They look like much later model years
Edit: They look just like the wheels that were on my 98 GMC Savanna van trim rings and center caps that were held in place with the plastic lig nut caps
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 11-10-2021, 12:08 PM   #19
dagnabbitt
dagnabbitt's Avatar
That's correct, I imagine that those would work with conversion lug nuts and modern hub covers. I just picked up a set myself. At that price it's a good option if you are into that look.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-11-2021, 02:19 PM   #20
lts70
1970 Daily Driver
lts70's Avatar
Re: 16Β” Tires on C20
Well I bought the rims and tires before coming back to this post.... I did plan on using the hub caps dang it.
Has any one added the s clips to make them work?
https://www.pelicanparts.com/More_In...BoCEDsQAvD_BwE
Old 11-11-2021, 03:37 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
245 75 16 on a 7 inch wheel
Old 11-16-2021, 02:14 PM   #22
lts70
1970 Daily Driver
lts70's Avatar
Got the rims. Hoping I can drill and tap three or four holes and use button head machine screws to Act as the missing knobs to hold on hubcaps. I set one on there to see how it would look. If I’m successful I will post to pictures.
Old 03-31-2022, 03:35 PM   #23
steveimpala
I can't recall if I had posted pictures of the new tires in another thread or not...well these are Firestone LT 265 / 75R 16...I also had the rims powder coated white ( the originals were silver ) I like how the white shows against the black ! I'm also attaching the SPID, would like to know the type of rear-end / ratio ( I'll write this down this time )
Thanks again !
Steve
Old 03-31-2022, 03:43 PM   #24
dagnabbitt
dagnabbitt's Avatar
Thanks again !
Steve
Off topic, but never seen a "miscellaneous lamp" option before. Nice truck.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 03-31-2022, 03:46 PM   #25
steveimpala
Thanks ! Good point, would it be interior lights ?
