remove AN adapter from corvette filter
How do you remove the "out" side? There is a lip on the adapter that won't let me remove it. See picture below.
I've tried several different fuel line removal tools and they don't work.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() Last edited by TA_C10; 11-03-2021 at 09:22 PM. |
Re: remove AN adapter from corvette filter
You can see the fingers that hold the fitting in in your first picture. I do not believe the tool you were using has long enough fingers?
If you can’t figure it out or someone else doesn’t chime in I’ll see if I can find the tool I use.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
You need one of these:
https://www.amazon.com/OTC-6509-Fuel...40988629&psc=1 It is made to fit in tight spaces. |
This makes sense, thanks guys. Tool ordered.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
Just FYI they have the same tool at car parts stores.
BMW & ASE Master Certified
probably could have just cut some of the excess off of the end of the tool as it does nothing??
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
