11-12-2021, 12:38 AM | #126 |
Re: 1970 C30 Car hauler Buildish thread.
I moved the driver side shock mount behind the axle to match the dodge bracket.
20211027_210329 by jarrod vanwinkle, on Flickr 20211027_210340 by jarrod vanwinkle, on Flickr 20211027_210919 by jarrod vanwinkle, on Flickr I cam across some assist shocks for cheap. I don't know if they actually do anything it says it gives any extra 500lbs of load on each shock and supposed to give a little lift idk but they sit at the same height as the old ones. that said i'm running helper bags any ways to help keep the load level. and its way cheaper then replacing the old leaf springs. 20211027_145259 by jarrod vanwinkle, on Flickr 20211027_212021 by jarrod vanwinkle, on Flickr 20211027_213118 by jarrod vanwinkle, on Flickr Pulled my step fathers boat out of the water on november 1st it was 71 out here it was a warm fall. 20211026_175543 by jarrod vanwinkle, on Flickr 20211026_180542 by jarrod vanwinkle, on Flickr started on the wide body extensions. 20211104_153546 by jarrod vanwinkle, on Flickr 20211104_161715 by jarrod vanwinkle, on Flickr 20211104_192849 by jarrod vanwinkle, on Flickr the steel wheels have a slightly deeper offset so I needed to make sure they fit. I have about an inch of room 20211104_202457 by jarrod vanwinkle, on Flickr 20211104_202519 by jarrod vanwinkle, on Flickr 20211105_142617 by jarrod vanwinkle, on Flickr I ended up going with dodge style u bolts so I had to redo the helper bag mounts. 20211101_194706 by jarrod vanwinkle, on Flickr 20211105_200749 by jarrod vanwinkle, on Flickr 20211106_141838 by jarrod vanwinkle, on Flickr Had another 71 degree day yesterday november 10th. 20211108_174112 by jarrod vanwinkle, on Flickr Got one more use out of the grill. 20211110_172043 by jarrod vanwinkle, on Flickr 20211110_172557 by jarrod vanwinkle, on Flickr 20211108_194312 by jarrod vanwinkle, on Flickr 20211108_193520 by jarrod vanwinkle, on Flickr 20211109_163550 by jarrod vanwinkle, on Flickr Had a new drive shaft made for the rear. and had them balance it and replace the carrier bearings and they replaced the u joints as well. I about had a hart attack when I got the bill. 20211110_191747 by jarrod vanwinkle, on Flickr 20211111_195122 by jarrod vanwinkle, on Flickr I wired up two 7 pin trailer plugs one for the gooseneck and one for the normal hitch. 20211111_215045 by jarrod vanwinkle, on Flickr 20211111_210344 by jarrod vanwinkle, on Flickr |
11-13-2021, 11:59 AM | #127 |
6>8 Plugless........
Nice work on it. I like your junction box for your trailer connectors. Nice work on the bag mods and bed widening. If has been a warm fall. Next week around here is going to be warm too. Sounds great to me!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-17-2021, 10:13 PM | #128 |
Great work on the boxes and doors
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
12-30-2021, 11:56 PM | #129 | |
Thanks, I can't wait to get the other side skinned. I hope you all have a wonderful new year! Photo dump. 20211111_221907 by jarrod vanwinkle, on Flickr 20211112_153643 by jarrod vanwinkle, on Flickr 20211112_155808 by jarrod vanwinkle, on Flickr 20211113_200358 by jarrod vanwinkle, on Flickr 20211113_201401 by jarrod vanwinkle, on Flickr 20211113_201915 by jarrod vanwinkle, on Flickr 20211113_201857 by jarrod vanwinkle, on Flickr 20211113_204712 by jarrod vanwinkle, on Flickr 20211114_155826 by jarrod vanwinkle, on Flickr 20211114_200548 by jarrod vanwinkle, on Flickr 20211116_195214 by jarrod vanwinkle, on Flickr 20211114_200556 by jarrod vanwinkle, on Flickr 20211120_163340 by jarrod vanwinkle, on Flickr 20211120_163344 by jarrod vanwinkle, on Flickr 20211120_163415 by jarrod vanwinkle, on Flickr 20211120_170609 by jarrod vanwinkle, on Flickr 20211121_192454 by jarrod vanwinkle, on Flickr 20211121_192712 by jarrod vanwinkle, on Flickr 20211124_194438 by jarrod vanwinkle, on Flickr Finally got around to making a stool out of a crark that came out of a jeep my brother through a rod in. 20211128_161848 by jarrod vanwinkle, on Flickr 20211128_184304 by jarrod vanwinkle, on Flickr 20211129_184745 by jarrod vanwinkle, on Flickr 20211130_213927 by jarrod vanwinkle, on Flickr 20211202_143323 by jarrod vanwinkle, on Flickr Also made a pair of lamps. 20211202_205254 by jarrod vanwinkle, on Flickr 20211216_152143 by jarrod vanwinkle, on Flickr 20211216_152205 by jarrod vanwinkle, on Flickr 20211216_152224 by jarrod vanwinkle, on Flickr 20211211_130042 by jarrod vanwinkle, on Flickr Then I decided to make a some ornaments to give everyone for christmas This was way to heavy to hang on a tree 20211211_203900 by jarrod vanwinkle, on Flickr So I ended up making trees 20211220_220220 by jarrod vanwinkle, on Flickr 20211220_195116 by jarrod vanwinkle, on Flickr 20211220_215958 by jarrod vanwinkle, on Flickr decided on a side exit for the exhaust. 20211206_161808 by jarrod vanwinkle, on Flickr 20211206_200358 by jarrod vanwinkle, on Flickr 20211206_201203 by jarrod vanwinkle, on Flickr 20211213_203615 by jarrod vanwinkle, on Flickr 20211229_151045 by jarrod vanwinkle, on Flickr 20211229_155246 by jarrod vanwinkle, on Flickr 20211214_193915 by jarrod vanwinkle, on Flickr 20211214_202011 by jarrod vanwinkle, on Flickr 20211214_202014 by jarrod vanwinkle, on Flickr 20211215_193855 by jarrod vanwinkle, on Flickr 20211222_214849 by jarrod vanwinkle, on Flickr 20211222_163542 by jarrod vanwinkle, on Flickr 20211230_192012 by jarrod vanwinkle, on Flickr 20211230_193643 by jarrod vanwinkle, on Flickr 20211230_200740 by jarrod vanwinkle, on Flickr 20211230_200745 by jarrod vanwinkle, on Flickr 20211230_200752 by jarrod vanwinkle, on Flickr 20211230_204543 by jarrod vanwinkle, on Flickr 20211230_204548 by jarrod vanwinkle, on Flickr 20211230_210045 by jarrod vanwinkle, on Flickr |
01-03-2022, 11:57 AM | #130 |
You spent a lot of time with the plasma cutter on those trees. Nice little gift though. I like the exhaust exit. Looks good
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
08-15-2022, 01:08 AM | #132 |
My buddy that I painted his truck gave me an old warn winch that he got on trade. He though it was told it was an 8k but it is a 6k. but after I did a bit of research on them it has the same gear ratio as the 9k winch. so I'm going to upgrade the motor and motor plate and make it a 9k winch.
20220719_201348 by jarrod vanwinkle, on Flickr 20220719_213423 by jarrod vanwinkle, on Flickr 20220719_213439 by jarrod vanwinkle, on Flickr 20220719_213711 by jarrod vanwinkle, on Flickr 20220720_213529 by jarrod vanwinkle, on Flickr 20220724_172049 by jarrod vanwinkle, on Flickr 20220724_165146 by jarrod vanwinkle, on Flickr I really love the look of the old warn 8274 I I made a fake 8274 gear case to give my winch a period correct look of something you would see on a old ramp truck from the 70s/80s 20220727_201851 by jarrod vanwinkle, on Flickr 20220727_201847 by jarrod vanwinkle, on Flickr 20220727_201854 by jarrod vanwinkle, on Flickr 20220727_210311 by jarrod vanwinkle, on Flickr 20220727_210317 by jarrod vanwinkle, on Flickr 20220731_155029 by jarrod vanwinkle, on Flickr 20220731_155034 by jarrod vanwinkle, on Flickr 20220731_155038 by jarrod vanwinkle, on Flickr 20220731_155043 by jarrod vanwinkle, on Flickr 20220802_172650 by jarrod vanwinkle, on Flickr 20220802_172610 by jarrod vanwinkle, on Flickr 20220802_172638 by jarrod vanwinkle, on Flickr 20220803_090524 by jarrod vanwinkle, on Flickr 20220808_153207 by jarrod vanwinkle, on Flickr |
03-07-2023, 11:04 PM | #133 |
Its been a while since I have posted. I have not stopped on the truck. I have just gotten lazy with my up loads.
Back last year after I finished the winch I installed a York compressor I have had sitting since 2012 I always planed on using it for onboard air on something but just have not. Its a york 206 https://www.tmcom.com/~tsm1/scout/faq/york.html 20220804_002321 by jarrod vanwinkle, on Flickr 20220801_015400 by jarrod vanwinkle, on Flickr 20220801_015435 by jarrod vanwinkle, on Flickr 20220804_002334 by jarrod vanwinkle, on Flickr 20220804_232407 by jarrod vanwinkle, on Flickr 20220807_161254 by jarrod vanwinkle, on Flickr I rebuilt it and made some mounting brackets for it. I attached it to the alternator. 20220808_224532 by jarrod vanwinkle, on Flickr 20220808_224524 by jarrod vanwinkle, on Flickr 20220815_153505 by jarrod vanwinkle, on Flickr 20220815_153459 by jarrod vanwinkle, on Flickr 20220815_153451 by jarrod vanwinkle, on Flickr 20220815_153456 by jarrod vanwinkle, on Flickr 20220815_154321 by jarrod vanwinkle, on Flickr the pully is from https://www.cuoffroad.com/product-li...om-components/ 20220815_153230 by jarrod vanwinkle, on Flickr V1 20220815_161049 by jarrod vanwinkle, on Flickr 20220815_161056 by jarrod vanwinkle, on Flickr 20220821_205202 by jarrod vanwinkle, on Flickr V2 I built a breather oil catch can. as oil was coming out of the breather. 20220831_200150 by jarrod vanwinkle, on Flickr 20220831_200154 by jarrod vanwinkle, on Flickr I drilled and tapped the intake so I could add a better air filter. 20220911_192717 by jarrod vanwinkle, on Flickr 20220911_193916 by jarrod vanwinkle, on Flickr I added a in cab air pressure gauge. 20220922_131612 by jarrod vanwinkle, on Flickr 20220926_160843 by jarrod vanwinkle, on Flickr I added a water/ oil separator 20220810_210024 by jarrod vanwinkle, on Flickr 20220810_210014 by jarrod vanwinkle, on Flickr |
03-07-2023, 11:28 PM | #134 |
I built a new shifter! It started out as a old Hurst 4 speed shifter that I found in our barn when we bought the house. back in 05 I think?
I cant find some of the pics. The chrome was coming off it was super rusty and pitted. In this pic it looks like i just finished sanding all the chrome a pits off of it getting ready to cut it. 20220816_205308 by jarrod vanwinkle, on Flickr I made some brackets to be able to bolt it on and make it height adjustable. 20220816_214714 by jarrod vanwinkle, on Flickr here is the bracket welded in place and the shifter polished. before I copper and nickel plated them. 20220817_144102 by jarrod vanwinkle, on Flickr 20220817_220502 by jarrod vanwinkle, on Flickr 20220817_221246 by jarrod vanwinkle, on Flickr 20220817_221449 by jarrod vanwinkle, on Flickr 20220817_221826 by jarrod vanwinkle, on Flickr 20220821_202427 by jarrod vanwinkle, on Flickr here it is after nickel plating 20220822_221831 by jarrod vanwinkle, on Flickr I made a shift knob out of a old curtain rod end 20220823_124300 by jarrod vanwinkle, on Flickr |
03-08-2023, 12:05 AM | #135 |
added a second row taillights
20220908_134649 by jarrod vanwinkle, on Flickr installed wench cable 20220918_194706 by jarrod vanwinkle, on Flickr tuched up the rockers 20221004_154010 by jarrod vanwinkle, on Flickr went to a swap meet. 20221007_134359 by jarrod vanwinkle, on Flickr Picked up a hose real at the swap meet 20221009_145010 by jarrod vanwinkle, on Flickr 20230307_223834 by jarrod vanwinkle, on Flickr 20230307_223819 by jarrod vanwinkle, on Flickr installed a new radio its ok no cutting to the dash! 20221006_003318 by jarrod vanwinkle, on Flickr Fall pics in the front yard 20221018_135117 by jarrod vanwinkle, on Flickr 20221018_135134 by jarrod vanwinkle, on Flickr 20221018_135153 by jarrod vanwinkle, on Flickr 20221018_135204 by jarrod vanwinkle, on Flickr installed a steering wheel cover the color matches better in person but not more sticky steering wheel! 20221023_212020 by jarrod vanwinkle, on Flickr 20221023_212103 by jarrod vanwinkle, on Flickr 20221023_212048 by jarrod vanwinkle, on Flickr I made a really bad decision I used a wipon clear coat it look great from 15 feet but it has a lot of runs 20221025_193003 by jarrod vanwinkle, on Flickr 20221103_132601 by jarrod vanwinkle, on Flickr 20221116_173428 by jarrod vanwinkle, on Flickr I reinforced the dove tail and added d rings 20221102_192006 by jarrod vanwinkle, on Flickr 20221102_194241 by jarrod vanwinkle, on Flickr 20221102_194235 by jarrod vanwinkle, on Flickr 20221102_210128 by jarrod vanwinkle, on Flickr 20221102_210113 by jarrod vanwinkle, on Flickr Took it for its first haul 20221109_152506 by jarrod vanwinkle, on Flickr 20221109_152456 by jarrod vanwinkle, on Flickr 20221109_172350 by jarrod vanwinkle, on Flickr then a month later the DD broke down lol 20221127_164244 by jarrod vanwinkle, on Flickr 20221223_170252 by jarrod vanwinkle, on Flickr 20221223_170306 by jarrod vanwinkle, on Flickr led head lights 20230216_132145 by jarrod vanwinkle, on Flickr 20230216_132202 by jarrod vanwinkle, on Flickr installed a work light for the bed it came of the YJ I had. 20230222_210225 by jarrod vanwinkle, on Flickr 20230222_210236 by jarrod vanwinkle, on Flickr 20230222_210527 by jarrod vanwinkle, on Flickr 20230222_210553 by jarrod vanwinkle, on Flickr 20230222_210602 by jarrod vanwinkle, on Flickr |
Tags |
air ride, c30, cummins, nv4500, ramp truck |
