Old 11-15-2021, 09:30 PM   #1
pjmoreland
pjmoreland's Avatar
WTB - 3 Groove Crank Pulley for SBC with Short Water Pump
I've currently got a two-piece two-groove crank pulley setup, and I'm looking to go to three grooves so I can add A/C. I believe I only need a new inner pulley with two grooves to go with my current outer single-groove piece. Please correct me if I'm wrong.
pjmoreland is offline   Reply With Quote
Old 11-15-2021, 11:39 PM   #2
daddymoo2
Re: WTB - 3 Groove Crank Pulley for SBC with Short Water Pump
I hope this helps. The part number is 3744043 this is the 2 groove pulley. Still can be purchased thru GM. Can also be purchased on EBay. If you need more help let me know I have this pulley setup on my 72 with factory air. Thanks Don
daddymoo2 is offline   Reply With Quote
Old 11-16-2021, 12:20 AM   #3
pjmoreland
pjmoreland's Avatar
Thank you! I'll order a new one.
Old 11-16-2021, 12:24 AM   #4
daddymoo2
The other pulley #3751232 would be the power steering pulley single groove. That should you there. Don
Old 11-16-2021, 12:40 AM   #5
pjmoreland
pjmoreland's Avatar
Do you think my existing single groove crank pulley for my PS will work with the double groove pulley?
Old 11-16-2021, 02:18 AM   #6
Classic Bowties
Always on the hunt...
Yes, you are on the right track and it should be as simple as swapping the single groove inner crank pulley out for the two groove inner and then reinstalling the outer p/s add on. If working with an OE style swp (LH/drivers side alternator) bracket/pulley setup, what year is your setup, are your existing pulleys OE GM pieces and if so do you know any of your pulley p/n's? Had you mentioned needing the crank pulley, we could have added/combined a swp inner two groove crank pulley (OE used $35.) in with Fridays steering column parts order. Don's above added pulley p/n info looks good for small block 72 models, so if you are going to be buying/chasing the above mentioned 3744043 BA two groove inner crank pulley then you should also have the matching short water pump two groove pulley p/n 3995646 AH (see below). Let us know if we can help with any OE swp pulleys, Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 11-16-2021, 09:56 AM   #7
pjmoreland
pjmoreland's Avatar
I'm planning on installing a Vintage Air system on my non-A/C 1968 truck. Based on what I've read on their website, my understanding is that OEM A/C pulleys should line up with their aftermarket compressor that mounts on the passenger side of the engine. I have the original non-A/C pulleys on my truck currently, along with power steering. I have purchased a two groove water pump pulley, but I will need to check the part number to verify it is the same as the one you posted. I will take you up on your offer for the OE two-groove crank pulley, but let me check the part number of my water pump pulley in case I need that too. I am out of town right now so I won't be able to check until later this week. Thank you for your help!
Old 11-19-2021, 04:54 PM   #8
pjmoreland
pjmoreland's Avatar
I'd like to purchase the following two OE items from you, if you've still got them.
3744043 BA Crank Inner Two Groove Pulley
3995646 AH Water Pump Two Groove Pulley
Old 11-19-2021, 07:18 PM   #9
Classic Bowties
Yes, we can supply you with both of those requested pulley p/n's and will get you some pictures and combined pricing info returned later today. Thanks, Mel
Old 11-20-2021, 03:56 AM   #10
pjmoreland
pjmoreland's Avatar
Sounds good. Thanks.
Old 11-20-2021, 04:18 AM   #11
Classic Bowties
Here are some pics of the requested 646 AH water pump pulley and the 043 BA inner crank pulley for 72 small block w/air conditioning, will offer you both pulleys for $65. and combine ship the pair for $12. via USPS priority. Thanks, Mel
Old 11-20-2021, 10:44 AM   #12
pjmoreland
pjmoreland's Avatar
Do either of the pulleys have pitting from rust, or is there only surface rust?
Old 11-20-2021, 02:00 PM   #13
Louisvillekytruck
What part number is the other crank pulley
Louisvillekytruck is offline   Reply With Quote
Old 11-20-2021, 07:38 PM   #14
Classic Bowties
Just surface and after sandblasting, both pulleys will look like the below pictured pulleys and the one that I posted in above reply #6. We do not currently have anything else to go right now but could get the two pulleys out to my blast guy, cost would probably be $20.-$25. and would need to allow for a 3-5 business day turnaround time. Let us know, Mel
Old 11-20-2021, 07:55 PM   #15
pjmoreland
pjmoreland's Avatar
Surface rust is just fine. I bought another pulley recently, and it ended up having serious pitting, so I just don't want to repeat that mistake. I'll send payment shortly.
Old 11-20-2021, 08:02 PM   #16
pjmoreland
pjmoreland's Avatar
Payment sent
Old 11-20-2021, 08:24 PM   #17
Classic Bowties
If asking for 72 small block applications, the other stack/add on single groove outer crank pulley for driving the p/s pump would be p/n 3751232 BB and the matching single groove pulley on the p/s pump would be p/n 3993325 DJ. Here are a few pics of a complete OE power steering changeover removed from a 72 2wd S/B 350 truck showing the matching p/s pump mounting brackets along with both of the mentioned 232 BB and 325 DJ pulleys. Mel
Old 11-20-2021, 08:57 PM   #18
Rick Bollinger
Is this also the correct parts for a 68 w/ps and factory air? Short water pump.
Rick Bollinger is offline   Reply With Quote
Old 11-20-2021, 11:29 PM   #19
Louisvillekytruck
If asking for 72 small block applications, the other stack/add on single groove outer crank pulley for driving the p/s pump would be p/n 3751232 BB and the matching single groove pulley on the p/s pump would be p/n 3993325 DJ. Here are a few pics of a complete OE power steering changeover removed from a x72 2wd S/B 350 truck showing the matching p/s pump mounting brackets along with both of the mentioned 232 BB and 325 DJ pulleys. Mel
Thank u mel .what trucks had the cast crank pulley was it 4wd or 2wd or both and years
Old 11-23-2021, 12:24 AM   #20
Classic Bowties
Payment sent
The pair of pulleys are headed your way, the package went out via USPS priority on Mon. 11/22 and the expected delivery day is this Wed. 11/24. Thanks again for the repeat business and let me know if we can help with any other 67-72 parts needs, Mel
Old 11-23-2021, 12:25 AM   #21
pjmoreland
pjmoreland's Avatar
Thank you!
Old 11-29-2021, 12:41 AM   #22
pjmoreland
pjmoreland's Avatar
The pulleys arrived safely. Thank you for your help.
-Patrick
Old 12-08-2021, 12:03 PM   #23
zeusflash
zeusflash's Avatar
I also am looking for a double groove crank pulley as well as a 3993325 p/s pump pulley
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 12-08-2021, 04:10 PM   #24
Classic Bowties
Hey Mike, we got your phone message last night and will be giving you a ring back today to discuss your bracket and pulley needs. Thanks for the inquiry, Mel
Old 12-08-2021, 04:52 PM   #25
zeusflash
zeusflash's Avatar
Great thanks!
'71 CST Blazer
'72 GMC 3/4 4x4
