Old 07-22-2004, 12:22 AM   #1
72dually
72dually's Avatar
OH MAN I wanna blow my truck up!
Normally Im patient, Im mechanically inclined, i.e. rebuild my own motors, swap/set up posi units in pegleg rearends etc, etc, but this fricken steering box has got me so pissed. The damn box was leaking at the shaft where the pitman arm attaches, so I go out to napa get the seal kit just for the lower end, remove the pitman arm, lock ring, and Ive spent 2 hrs trying to get the seals out, I poped the cover on top of the box, push the shaft up from the bottom a inch or 2 thinking the seals would slide off........NOPE.
Napa told me to turn the steering wheel from lock to lock and the seals would come out, that didnt work, what the heck am I doing wrong?? Do I need to pull the shaft completely out from the top, there were'nt any instructions in the box when I got home, and everythings closed now
72dually is offline   Reply With Quote
Old 07-22-2004, 09:06 AM   #2
64fleetside
I use a small sheetmetal screw driven into the seal(maybe 2) then pry out seal using the screws. Brian
64fleetside is offline   Reply With Quote
Old 07-22-2004, 01:20 PM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
Its been posted before, but try starting the truck with the pitman arm off and turn the steering wheel. The pressure is supposed to push the seals out.
I did mine last year and took them out the hard way using a bent tip scribe and screw drivers, anything I could think of actually. Good luck.
Mike
hgs_notes is offline   Reply With Quote
Old 07-22-2004, 04:45 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yep, put a drain pan under it, start the truck and turn the wheel back and forth. Pop, splash, drip.
Never fails.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-22-2004, 08:28 PM   #5
guyryan100
guyryan100's Avatar
If you decide to blow it up, get some pics for the boardmembers...
guyryan100 is offline   Reply With Quote
Old 07-22-2004, 11:31 PM   #6
72dually
72dually's Avatar
Guyryan100.......... nothing I like better than someone with a sense of humor...lol, thats funnier than ****
Tx Firefighter....... I drove the truck around town today with the pitman arm about half way bolted down, whohoo........man was that think a joy to drive, it was all over the road, and the funny thing is, they never poped out with no snap ring at all......craziest thing
hgs_notes & 64fleetside......I think I'll try these methods, before I get the C-4
Old 07-23-2004, 07:00 AM   #7
Tx Firefighter
I just take the pitman arm completely off, remove snap ring, start engine and turn the wheel lock to lock until it pops out.
Never seen it fail yet, and I think I have changed that seal on every postal truck in North Texas. Well, it seems that way, but a few hundred of them at least.
Old 07-23-2004, 07:43 AM   #8
Mudder
Mudder's Avatar
Is blowing a truck up sorta like cutting your dash???????????? You just might get in trouble around here hehe..........
Mudder is offline   Reply With Quote
Old 07-24-2004, 03:22 PM   #9
72dually
72dually's Avatar
Tx firefighter......I tried that for an hour plus, and they would'nt come out, so I resorted to putting some screws in the seals, and still pry'd on them for 30 minutes, they did finally come out. I checked the bore to see if they're was any rusting, pitting, or some reason why the problem, but the bore was shiny smooth. slid the new seals and washers with ease, and no leaky
