#151 |
![]() Join Date: Apr 2010
Re: 1950 Chevy 3600 Woody R
We got the front suspension back together
we chose blue polyeurothane for bushings and boots it got all new everything (except for rotors they were fine)
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-25-2021 at 10:06 AM. |
#152 |
I decided to paint the calipers interior blue
That should really make them pop!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-25-2021 at 10:05 AM. |
#153 |
We got a lot done today!
First we finished up the front suspension We installed the blue calipers And I was right, they do pop!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-27-2021 at 11:17 AM. |
#154 |
Then we assembled more stuff on the engine
The chrome alternator went on We painted the dipstick blue, and put a fancy vintage air manifold on the AC compressor Then we took it off the stand and coupled the transmission
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-27-2021 at 11:16 AM. |
#155 |
We then put the drivetrain in the chassis
The drivetrain is even at the proper 4 deg angle!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-27-2021 at 11:15 AM. |
#156 |
And prepped the cab for mockup (this includes drilling the mount holes)
Monday we will mock up the cab, finalize positioning of the drivetrain, build the motor mounts, fabricate the Transmission tunnel, and measure for driveshaft length
#157 |
![]() Join Date: Sep 2017
Good day's work.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#158 |
yeah, we’ll prolly make up for it by getting very little accomplished Monday!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
#159 |
Ok, I am now laughing out loud.
Yes, I know the syndrome of which you speak.
#160 |
Right? I’m usually afflicted by it!
#161 |
Ok, I'm sure someone will not like that we are off topic on the build, but I'm still chuckling about that Monday comment.
#162 |
It’s my thread, I’ll say what I want! Glad you appreciate my humor
#163 |
Yep!
#164 | |
![]() Join Date: May 2007
nice work chris!
#165 |
So we mocked up the cab today
set where the drivetrain will be The engine has the proper 4deg rake Looking absolutely killer!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-30-2021 at 10:53 AM. |
#166 |
Built the Transmission tunnel today
Wanted to get it done before we ran the fuel line (fire hazard, ask me how I know) all tacked in, ready to seam seamed and leaksealed The floors are officially done, ready for sound deadener, jute padding, and carpet!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-30-2021 at 10:52 AM. |
#167 |
Here’s the engine shot of the chassis
we took apart the rear brakes to inspect them. The right rear wheel cylinder is blown and leaked brake fluid all over the shoes, ruining them We started out to undercoat the whole frame, but ran out, will pick some more up tomorrow Got the modified Transmission crossmember tacked and ready to seam weld tomorrow
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 11-30-2021 at 10:51 AM. |
#168 |
It is coming together nicely.
How did you bend the tranny cover? Also, what brand of wheels are those?
#169 |
8man-I used a piece of 4” PVC 2' long to form the tunnel.
The wheels are Boyd Coddington
#170 |
Thanks. Old fashioned ingenuity on bending that roll for the tranny cover.
#171 |
#172 |
Not many pictures today, but lots accomplished
We finished painting the frame today Built the offset drop blocks for the rear, tomorrow we’ll install the drop Finish welded the Transmission crossmember Worked on fabricating the AC lines for the cowl
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-01-2021 at 12:15 PM. |
#173 |
Looks like you and the guys are working well together. Things are moving.
If you don't mind, I'd like to see the AC hose routing from stem to stern. I did the Vintage Air on the 48, but don't really like the hoses running through the firewall and was thinking about something like what you are doing for my 54.
#174 | |
#175 |
What unit are you using, and I see the lines going through the side to get inside the fender, but I've never seen how they get mounted and run back through to the compressor and the coil.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
