#301 |
![]() Join Date: Feb 2009
Re: Build that 71 402 already
Nice to finish this area of the dash.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#302 |
![]() ![]() Join Date: Jan 2005
Beautiful!
#303 |
Early in this project I picked up the NOS dome light bezel. They're not exactly plentiful in bling.
Last night I couldn't sleep thinking about installing it after figuring things out. When I took the old one down I thought it installed with screws right ![]() I hear they rattle, go figure, the one in my C20 has clear sealant around the outer parameter - not really a nice look. I figured 3M strip caulk has a place here, avoiding clip & lens interference. Once figured out I think it took a minute to install that & the harness. Snugged right up. I imagine there's little or no visual difference this & repro. though. Speak of harnesses, I ordered them last January, and it only took 11 months to get them. Really I never got the turn switch, but I found an NOS. Wouldn't surprise me I receive the turn switch at some point. They sent the harnesses as they built them. Yeah, 11 months worth so far. Love COVID & that, maybe the chinese can build the harnesses too ![]() For anyone wondering how to remove these, the clips on the housing only spring one side each. The RH clip spring is accessed from underneath & the LH clip spring from above. Perhaps a good place for a credit card.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-06-2022 at 02:22 AM. |
#304 |
When my body & paint guy offered to paint the grille I didn't know he was going PAINT the grille, pictures can't do it justice, at all.
He sprayed it twice, because the first time exposed marks inside the cells, probably natural, but he wasn't having it, so he sanded everything smooth, hit it again and used the same clear coat he sprayed the body with. It's heavier than once before for sure. This is near as much his project as mine, couldn't do it without him. I pay him say 50% more than he wants though, on-going ![]() ![]() It's the same grille I installed new early 90s, seems it was $50-60 at a place called Chevyland. It was better than the NOS acquired over the years, so off to bed. Be a good day when I install it - the truck will have returned from its maiden start, God willing ![]()
#305 |
looking good Tony
#306 |
Finished the steering and tailgate yesterday. We started on the doors only to find out the original 3M tape on original molding clips are no good after 40-50 years
#307 | |
![]() Join Date: Dec 2009
Probably give 3M a call on Tuesday for warranty ![]()
#308 |
![]() Join Date: Jan 2007
Oooooh pretty
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#309 |
These updates are fantastic, hard work pays off.
#310 |
Thanks.....
Well I finally tied in the shift this and that, and the steering column this and that too, what an adventure. As steering goes, first I had to do it wrong to do it right, not a big deal. Turns out you can't install the upper steering shaft correctly with the intermediate shaft mounted to the rag joint, go figure. Anyway, got that done the other day and was happy to see I didn't have to mess with the steering box & rag joint formerly installed. So then came the shift business today, which kept me running for a while. I tried installing what I thought might be the correct assm. for the bottom of the shift control rod to the shift shaft control cross using kit 1394293 / 22503153. Yeah, but not really, my fingers are real sore. I can't see that kit working, couldn't install what I know as the right spring clip. Perhaps there are different rods or clips. .............. So I went with what I knew would work by tailoring a single flange grommet (aka step bumper # PBCS51612). I inserted that into the cross from the LH side, added a regular flat washer on the RH side, and the clip slid in nicely while there's no play. Then came the flustering shift detent business for non-tilt, yeah that took a while. Once the positions added up, I ended up adjusting the play off the detent by finding a happy spot, and slowly tightening the lower strap over and over while repeatedly checking the shift, because even when I thought it was right, tightening the lower strap said nope, nope, not there either, nice try, not really close, yadda yadda.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-04-2022 at 08:43 PM. |
#311 |
Hung the doors and caught the hood springs today. I tell you this guy Josh is a God-send. When we dove in we didn't know what we were getting into, especially me. We dealt 10,500 for paint body & materials near 7 years ago. I'll end up around 18 not counting extras. He's never asked for a dime more than agreed on. I'm still getting a deal, how many guys do you know will pick up and deliver a cab and bed
![]() Dry run proved a nice guide but wasn't quite where we ended up most places. The RH is great, that the side that was t-boned. They punched 30 some holes in that door and bondo. Good to know it's all steel again, thanks to Josh. RH door latch proved a challenge, but by my eyes the LH side needs a slight adjustment. We lag bolted the hinges onto one of too many carts I've built for this disaster ![]() ![]() ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-07-2022 at 08:38 PM. |
#312 |
Installed the duct, compressor & finished the brakes, she's ready for fenders.
#313 |
Just a little update, hopefully she has a full body this Saturday, though I know we won't finish moldings or perhaps the skirts. I wonder if it would be worth it to fit the fenders, pull them to install with the skirts on? Hmm.
I freshened up the vacuum reserve can, wow what a nice piece. Hope it works ![]() I updated my to-do list today and a manual I'm writing and realized wholly cow, this project is nearly done. That's kind of a shock, so much time dedicated. I figure 100 hours my end to finish the truck and kit I've written. It will feel strange to be done.
#314 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Just in time for Spring. Nice!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#315 |
Nice work. I always dread,(and enjoy), this phase of a build. After one has been apart awhile, things just don't go as planned always. Thanks for the shift diagram as I am waiting for my linkage kit to get here this week, so I can get mine up on the trailer. Its always the little things.
Your paint looks great. It is going to be a super nice truck.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
#316 | |
The other day I installed the A/C vents assisted by an orange (literally) and heat gun ![]()
#317 |
great work Tony,it's coming together.what's next?take care.Greg
#318 |
Close man, we're going to finish it up May 28th. Works well, those fenders give me lots to do, I should start thinking about a battery. We're going to drop the rear LH hood a pinch, and grille is temporary. I'll install the "good one" after it's running.
#319 |
Wow, 6 + years later, after installing the rear harness today, I literally ran out of things to do on my truck, hmm. Go figure I hadn't ordered gaskets for the lenses, oh well. Some dependencies. We finish the body and moldings this Saturday, so the engine bay will soon be done, looking forward to it. Guess I'll need a battery soon.
How awesome if the glass guy could deliver, you'd think a year's notice is enough, same for the air cleaner my nephew's had 1+ year. Other than that, it's a gas tank, interior doors & seat away from being done on my end.
#320 |
Keep it up, it's looking great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#321 |
It's starting to look like a truck. The body is built. I installed some fun stuff in the engine bay today.
Picked up an NOS coolant expansion tank kit along the way. Against the kit's instructions, I routed the hose through the RH inner fender's drain hole. Pretty sure original radiator drain hose ran through it, so what the heck, it routes clean.
#322 |
I'm trying....
![]() Join Date: Oct 2013
So close. Looking great. Outstanding work as always Tony.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#323 |
I'm down to so few hours, but no sign of windows yet, that will come soon. I even get my air cleaner back today, out 1.5 years. I ordered the original seat cover, $900. Might take till Dec., so less the gas tank and a few loose ends, I think I better install the old seat to get this running say Oct.
Bummer I had all NOS Witek band clamps I liked a lot, but the #10 don't fit a 3/4" heater hose, they're for the bypass hose only. I ordered two of these, they might work instead. I also ordered clone tower clamps, just in case, yikes ![]() Dumb question. The factory installed a pad on the cab's wall for the fuel tank. Any reason why the fuel tank shouldn't receive the pad instead? seems a much better option. I'm using 1/8" neoprene rubber, and I have glue ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-03-2022 at 07:19 PM. |
#324 |
Amazing work!
#325 |
Good day to install a fuel tank. It was the "hardest" thing I had left to do.
For tips perhaps, I installed Classic Heartbeats grommet. Slid it on the filler neck with dish soap. Installed the tank loosely, with my son's help. Tried dish soap to get the grommet through, failed, probably not the soap. My son kept a blow drier on it while I started it from the inside, finished from the outside, not bad at all. All with a ball-end tool, I swear by them for installing grommets. NOS cap. And least it was before installed. 71 is a rare cap, I found this in 2017 for $35 ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-18-2022 at 08:11 PM. |
