LS to TH350
Ready to drop a gen3 vortec in 85 c10. Turbo 350 is already in the truck. I know I'll need the spacer plate and the longer bolts but can anyone who has done this before tell me if I'll need a new flexplate and starter as well? I'll be reusing the stock converter and the stock starter that came with the engine for now.
Thanks! |
Re: LS to TH350
I've never done an automatic LS, but with the manuals you face the dilemma where the flywheel face depth is 0.400 more shallow than the classic block, so I got a specialized flywheel that was that much thicker.
Maybe the spacer plate you refer to takes up that difference? I'm in for the solution because I'm curious!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Re: LS to TH350
Yeah I'm definitely sure the spacer makes that up. I'm not sure if a new flexplate and starter is necessary. In all the research I've done I haven't heard a definite yes or no on those
Re: LS to TH350
I just installed a 2003 5.3l from a Silverado in my 79 Silverado, and the easiest way to do it is to buy the hub adapter and use the stock LS flexplate. Then you just use standard torque converter bolts. The only thing you may have to do is open the mounting holes up a little on the flexplate. I didn't have to on mine because it'd already been mated to a TH400 when I bought it. You may also have to trim outer ear on the th350 depending on which exhaust manifolds / headers you use. I used the cheap headers they sell on ebay for swaps and had to trim the passenger side slightly.
https://www.amazon.com/Torque-Conver...4P4QWQ6WEVZZN6
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
Re: LS to TH350
Re: LS to TH350
I'll check that out. Thanks!
Re: LS to TH350
I have a th400 but the process should be the same. I used a spacer and stock ls flexplate. I had to open up the holes a little bit to get the 3 bolt torque converter on, but other than that, it bolted right up. I reused the factory starter. 2 of the holes on the engine/ transmission don't line up, so don't be concerned about that when you begin to fasten the two together
Re: LS to TH350
Working on swapping a LQ4 6.0 into my 72 K10. Stock LS starter is fine. My flex plate was the flat version and all I had to do was enlarge the bolt holes...4L80E has 6 bolts and the TH350 has 3. My tranny is in stock position and it is a tight fit to firewall, but so was the HEI distributor. I did not want the hassle of adjusting the drive shafts as mine is a 4x4, so I went with stock position. Fired mine up last weekend just to see if it would run and it ran great.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped---sold 1955 f100 LS swapped----sold 1968 C10 shorty project 1971 C10 longy project |
#9 | |
Re: LS to TH350
![]() Join Date: May 2015
Re: LS to TH350
bellhousing to engine dowel and bolt pattern is the same..except for one bolt..its a non issue..be sure to use 2 dowels..
I think he's referring to the number of torque convertor bolts..6 instead of 3 |
Re: LS to TH350
Yes the torque convertor bolts are what I am referring to.
Re: LS to TH350
I have one last question. Do any of you guys know what years of flex plates are interchangeable? For example, I went to a couple local junk yards this weekend and saw a lot of vehicles with the flex plate still in. The motor had been pulled or the trans pulled. I can't imaging GM making several different flex plates. My engine came off a 2000 silverado 1500. Anyone know what years I can pull from and still get what i need?
Re: LS to TH350
I can't say for sure, but I believe the flexplate from any 4l60e engine should work with the sleeve to mate to the th350. I've never read about any differences from year to year on the flexplate, though admittedly I've never had a reason to research that specifically.
#14 | |
Re: LS to TH350
#15 | |
Re: LS to TH350
#16 |
Re: LS to TH350
I'll throw this in, on mine I used the ol Ebay adapter plates, the ones that locate the rear of the LS engine in the same location as the ol sbc...the clam shells bolt to them, and it sits right in there.
Then your trans and driveshaft stay in their original location
#17 | |
Re: LS to TH350
There's so many options, it's hard to tell which ones are going to put the rear of the engine in the stock location. What you describe sounds like it should work for me though. |
#18 |
Re: LS to TH350
Yeah, mine have just one set of holes..
| Bookmarks |
| Thread Tools | |
| Display Modes | |
