Old 12-17-2021, 12:10 PM   #1
Mickeymotormount
Active Member
Mickeymotormount's Avatar
19.5 high clearance srw rims
Hey guys. Years ago I had a GMC 3500 Longhorn with 19.5 tubeless rims. I have sold the truck years ago () to keep the bride happy.
I am in search of the same rims for my 67 C20 build. I know they were available on P30 step vans and optioned on some pickups of that era.
Anyone know of a source for these in the Northeast? I have seen them on Ebay and Facebook Marketplace. I was hoping to find a set a little closer.
Thanks in advance to all!!
John
1967 C20 2WD Longbed
2001 2500 HD 4X4 Extended cab long bed
Mickeymotormount is offline   Reply With Quote
Old 12-17-2021, 09:51 PM   #2
Re: 19.5 high clearance srw rims
Can't help you, but I like your style. Good luck, I wish you luck in your search
Old 12-17-2021, 11:58 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
https://www.boarwheel.com/8-lug-rancher-19-5x6-75/
Seems reasonable
Old 12-18-2021, 09:16 AM   #4
Mickeymotormount
Active Member
Thanks for the replies guys.
Here is exactly what I am looking for, only closer to home.
John
Old 12-18-2021, 10:51 AM   #5
burnin oil
You may want to check the cost of tires before making that decision. One of my trucks has factory 19.5s and decent imports like kumho are pushing $400 a piece for a non highway tread. I know that there are some light duty tires making it to market now for the diesel truck crowd but last I checked they were pretty expensive also. My 5500 is averaging 20k miles a set and has had kumho, Hankook, and Goodyears on it and is due for set number 4 at 80k miles. This truck does wiegh 12k pounds empty. I want out from under the 19.5s but semi tires are my only option and wheel adapters are over a grand themselves and tires are around $600 each. The p30 rims are usually expensive when you can find them. Good luck.
burnin oil is offline   Reply With Quote
Old 12-18-2021, 10:58 AM   #6
Mickeymotormount
Active Member
Thanks for your concerns. This truck will only be a weekend cruiser once in a while. I will investigate the cost of the tires like you said, however.
John
Old 12-18-2021, 11:55 AM   #7
factorystock
factorystock's Avatar
X2! Hard to find and pricey, but the old school no nonsense look is priceless. '67 and '68's, have unique features that should be appreciated, if you got it, flaunt it ( look how those caps pop out of those rims ). Lot of food trucks ( bread trucks ) run the 8R-19.5, stay away from metric low profile tires.https://www.amazon.com/Double-Coin-R...9842433&sr=8-2 After clicking on this link, a microsoft edge link came up with $180.75 a piece.
factorystock is offline   Reply With Quote
Old 12-18-2021, 12:46 PM   #8
Mickeymotormount
Active Member
Thanks for the link Factorystock. And that picture is the look I am trying to achieve with my orange/white 67 C20. Wow even the truck in the pic is a '67 with the large back window option.
John
Old 12-18-2021, 12:54 PM   #9
jocko
jocko's Avatar
I would not recommend using 19.5 trailer wheels. Might be worth checking in with members oem4me, yelmer, or 60-66. I’d say that about half the 19.5s I’ve ever seen in existence have been on their trucks. Very, very hard to find. I spent quite some time tracking down a hodge-podged set of five 17.5 wheels. Finding what you seek locally will severely limit your market, unless you get lucky. If you’re determined, I’d open up the aperture, accept shipping cost pain, and scour CL, eBay, and post a WTB on this forum. If anyone has them stashed, they are probably members here. I think you are more likely to find them on the 60-66 side of the house.
Old 12-18-2021, 01:02 PM   #10
Mickeymotormount
Active Member
Not going to use trailer wheels. Looking for Kelsey-Hayes made rims GM used in the 1960s. Thanks for your insight about where to look. I will check around the forum to see what I can dig up.
John
Old 12-18-2021, 01:09 PM   #11
72c20customcamper
72c20customcamper's Avatar
I like the way they look. I'm keeping the 17s on my 68 with bias ply mudders on it keep the farm truck look since that's where it came from
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 12-18-2021, 01:09 PM   #12
factorystock
Last word of advice, make sure they are the "60's type 19.5" with the more positive offset, the "late 50's type 19.5" had the "flatter" style wheels.
Old 12-18-2021, 03:00 PM   #13
HO455
HO455's Avatar
And to make things harder they also were available on Internationals, Dodges and Fords too. I got my 17.5's from a Dodge guy because the Dodge hubcaps didn't fit.
This website may be able to help. I know they are a long ways away but they might have an east coast connection or be able to help with IDing the Chevrolet versions.
https://akhwheels.com/
Good luck. I love that look too.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 12-18-2021, 05:19 PM   #14
factorystock
Those makes did offer 19.5" wheels, but those wheels used inner bumps for hubcap retention, they only accept IH, Dodge and Ford hubcaps, not GM hubcaps. Wheels built for GM specifications had clips that accept period GM hubcaps.
Old 12-18-2021, 05:21 PM   #15
jocko
jocko's Avatar
Assumed not, but just mentioned because they were linked in post #3. Good luck with your search, I really like the look of the stock 19.5s on the older trucks in this era (and the 60-66 era).
Old 12-18-2021, 07:59 PM   #16
HO455
HO455's Avatar
Thank you I did not know that. It should help the OP weed though the other makes.
Would the late 40's and early 50's ford high clearance wheels have clips? The regular sized Ford wheels did.
RIP Bob Parks.
Old 12-18-2021, 09:22 PM   #17
factorystock
The 19.5" "high clearance rims" used by Ford were introduced in 1956 and used up to about 1966, never came with clips, just inner bumps. Dodge and Ford rims were identical.
Old 12-18-2021, 09:51 PM   #18
Mickeymotormount
Active Member
As far as I know, the Ford and Dodge rims would fit a Chevy, but not vice-versa. The inner hub diameter on the Fords and Dodges were larger than GMs allowing them to fit GM but not GMs to fit the Ford and Dodges. Bolt spacing remained the same between the big 3.
John
Old 12-18-2021, 09:56 PM   #19
Mickeymotormount
Active Member
I have seen those versions, but they don't look like these:
John
Old 12-18-2021, 10:33 PM   #20
Mickeymotormount
Active Member
Thanks for the tip. I did check there when I first got the truck(a year ago). They had 4 of them for $1200 plus shipping. I decided to wait until I was ready to start working on the truck. That time has now come and I am on the lookout for some.
John
Old 12-19-2021, 04:40 PM   #21
duallyjams
duallyjams's Avatar
Just a thought on possible option.I provided centers out of 17.5 wheels and had 17" wheels 8" wide made in Landenberg PA. This gives unlimited tire option. I had the wheels powder coated in Argent / Rally wheel silver.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-19-2021, 04:51 PM   #22
Mickeymotormount
Active Member
Attachment 2152675
Attachment 2152676
Thanks for the tip. I will keep that in mind.
John
Old 06-08-2022, 10:34 AM   #23
skippie69
Any luck finding these? I'm looking as well up here in Canada?
Todd
skippie69 is offline   Reply With Quote
Old 06-08-2022, 11:13 AM   #24
kwmech
Southern California, but they will ship
https://www.1800everyrim.com/
Old 06-10-2022, 07:16 PM   #25
factorystock
[quote=duallyjams;9008660]Just a thought on possible option.I provided centers out of 17.5 wheels and had 17" wheels 8" wide made in Landenberg PA. This gives unlimited tire option. I had the wheels powder coated in Argent / Rally wheel silver.
Looks great, if there is a will, there is a way. Now why can't the industry figure this out? A fortune could be made if they reproduce the 17.5" center piece with rivited clips for a common 16" wheel ring. It would be a godsend for '48-'68 3/4 ton owners who want to run period correct hubcaps.
