Old 12-31-2021, 06:18 PM   #1
Factory Guy
Factory Guy's Avatar
Fuel Tank-Squarebody?
Getting ready to put a new fuel tank in the Old Truck (on the Drivers side, only at this time). Ordered it from Rock Auto and it showed up in days.
I was shocked how quickly it showed up unlike all the horror stories I have been hearing about it taking weeks to get the tank and weeks to get the sender. So my question, the gas tank on this side is near empty of fuel, so dropping it won't be a problem. I saw one post where a guy used 3m (2229-pic below) isolating strips to insulate the tank from the straps. I guess they use these in professional plumbing jobs with copper pipe to protect it from touching the concrete it is imbedded in.
My guess after 50 years of the gas tank being in the truck the fuel tank strap isolators (like tar strips) will be shot.
Anybody else got comments?
Factory Guy is offline   Reply With Quote
Old 12-31-2021, 06:36 PM   #2
44th Miss Inf
Re: Fuel Tank-Squarebody?
I just use roofing tar paper. It looks to be what was used originally
44th Miss Inf is offline   Reply With Quote
Old 12-31-2021, 07:29 PM   #3
kglowacky
I used bicycle tubes and cut them in half then sliced them into strips
kglowacky is offline   Reply With Quote
Old 12-31-2021, 07:44 PM   #4
cadillac_al
I have done both of the above methods. That Scotch stuff sounds interesting. I don't know what it looks like but it just might be the best option.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-31-2021, 08:57 PM   #5
hatzie
Moderator
hatzie's Avatar
Roofing felt.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-31-2021, 10:48 PM   #6
Dead Parrot
Good bet on the old tar strips being bad. That is where my tank rusted out. Guessing the mostly tar-less strips started holding water at the rust out spot. The hole did rust from the outside. The rest of the tank was still in good condition.
I used some strips of neoprene door mat as I was out of roofing felt and didn't want to buy a new roll just for cutting a few inches of tank stripping.
Dead Parrot is offline   Reply With Quote
Old 01-01-2022, 05:26 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
its been a while since i did a tank on one of these but i have had to do three on my 1998 within the last two years. Make sure you insulate the tank well wherever the strap touches the tank, even if you have that plastic tank guard. they are making tanks cheap in china and they wear a pin hope with the friction . I put a couple of layers around the tank and sprayed the bottom with undercoat
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-01-2022, 06:22 PM   #8
72c20customcamper
72c20customcamper's Avatar
Every tank I've replaced the area under the straps is rusted . I assume it a combination of dampness and the grit grinding the galvanized coating off.
I use the roofing ice shield . Stays stuck to the tank so no grit gets between the tank and insulator .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-01-2022, 10:39 PM   #9
pound41
I was thinking of going with the sticky plastic/vinyl that they sell at Home Depot or Lowes.
You use it to line the threshold of a door or window, would take a few layers but it does have adhesive and is not crazy expensive
pound41 is offline   Reply With Quote
Old 01-03-2022, 10:24 AM   #10
sick472
sick472's Avatar
It's a big toss-up in my opinion. Felt-like materials soak up water, BUT also dry out easy...Rubber-like or tar-like materials don't soak up water, BUT can trap it. I redid both of my tanks on my K20 a couple years ago and did the following
Thoroughly cleaned the exterior, lightly scuffed, self-etch primed (the old reusable tank and the new one), then painted the tanks with a few heavy coats. I used rubber sheeting (about 1/10th inch thick) to put between the straps and the tank.
My thinking is that the heavy coats of paint and rubber strips will minimize rubbing and corrosion that ultimately causes the tank galvanized coating to disappear and allow rust to take ahold.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
