Old 07-23-2004, 11:58 AM   #1
Jonboy
Slots go on anything!
Need instrument cluster help!!
I need some help with the wiring plug on the tach dash I got for my Blazer. I have a 77, and have a 79 cluster. I have a mechanical gauge to fit the hole, so that is not a big convern. My question is about the wiring for the main cluster plug. Does anyone have a diagram for the plug, so I can repin what I have and make it work? I have the tach wiring figured out, just need help with the main plug. Thanks in advance!
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-23-2004, 01:47 PM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I just traced the circuits on the old dash, then for the new one. Move the wires for fuel sender from the old position to the new, then temp, etc.... Just draw a diagram of the connector, labeling with colors and circuit function, then move the wires to the correct position for the new dash. Good luck!!
NeCrOmAnCeR is offline   Reply With Quote
Old 07-23-2004, 01:53 PM   #3
Jonboy
I was going to do that, but I am lazy. Looks like that may be next week's project.
Old 07-23-2004, 02:17 PM   #4
Grim Reaper
BIG TIME MAJOR ELECTRICAL CHANGE FOR 78.
78 was the first year for the blade style fuse box. Oil presure went electric that year, gas door added, rear seat foot well and fold and tumble rear seat first year as well. LOTs of firsts. Your going to have to trace down the harnesses. Best place to start is your local library and see if the have the year spicific repair manuals on Microfisch. It's 10 cents a copy at mine.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 07-23-2004, 02:35 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Check a Haynes Manual for the trucks. That is what I use.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-25-2004, 10:14 PM   #6
Jonboy
Ok, I got the main plug wired, and eerything seems to work. Next question: where do I hook up the power lead for the tach? I put it to 12V switched power on the fuse box, and the tach needle swung 360 degrees. What did I do wrong there? I ran a wire from the "tach" port on the distributor cap, and grounded the black wire to the body.
Old 07-26-2004, 10:09 AM   #7
NeCrOmAnCeR
Does it work with the engine running? If not sounds like the tach needs to be fixed. Do you have any other ignition system besides stock? (MSD etc..)
Old 07-26-2004, 10:51 AM   #8
Jonboy
No, it's an HEI. I was thinking maybe my ground is not the best. I am going to try to fix that, and see what happens.
Old 08-02-2004, 11:28 AM   #9
Greg Carter
Jonboy,
Any progress with your tach? I just bought an '82 and the factory tach does the same thing. I measured the lead labled "12v" on the instrument cluster on the tach connector and there was nothing there, 0v. So I jumped 12v to it and the needle just swung all the way to max. I traced the wire (pink on my truck) all the way back to the fuse box and it is 0v there to. All the fuses are good. Can't figure this out.
Greg Carter is offline   Reply With Quote
Old 08-02-2004, 11:31 AM   #10
Jonboy
I haven't done anything to it yet. I tried to put the stereo in all weekend, and ended up doing everything else but that. I just left it unhooked for the time being.
