Old 01-03-2022, 08:37 PM   #1
Nickelcharlie
What oil are you using in an older flat tappet motor?
I have an 86 GMC with the original flat tappet motor. Should I be using an oil such as Rotella made for diesel motors or can I use a synthetic oil? I have also read once a flat tappet motor has been broken in correctly a synthetic oil can be used! So I would like to hear what you have been using successfully in your older motor for a long period of time?
My owners manual lists multi grade oils so I am thinking it is alright to be using any brand quality oil. Thanks for your input in advance!
Nickelcharlie is offline   Reply With Quote
Old 01-03-2022, 11:44 PM   #2
Bandit130
Bandit130's Avatar
Re: What oil are you using in an older flat tappet motor?
I had a cam/heads rebuild last April. Did some research and found recommendations to use oil that has zinc and phosphorus. Started using Valvoline VR1. Haven't noticed a difference but hopefully it is good for flat tappet cams. Do some research and decide the oil you would like to use.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 01-04-2022, 12:07 AM   #3
Getter-Done
Getter-Done's Avatar
I have started using Amsoil in my stuff.
I really like it.
Its a little higher than normal oil is currently.
So the liitle bit extra money is worth it too me for Better Oil.
Link: https://www.amsoil.com/lookup/auto-a...lume=us-volume
The early bird gets the worm,
85 Chevy K-20
Old 01-04-2022, 06:19 AM   #4
Hammered 77
Hammered 77's Avatar
I use "Brad Penns" oil, recommended by machine shop.
Rick
Hammered 77 is offline   Reply With Quote
Old 01-04-2022, 09:06 AM   #5
MJN
MJN's Avatar
I run AMSOIL Z-Rod 10w30 in my '74. I also used AMSOIL Break-in oil when I rebuilt the engine, no issues, no leaks and no consumption. Everything AMSOIL makes is full synthetic.
https://www.amsoil.com/p/z-rod-10w-3...motor-oil-zrt/
Another alternative to Z-Rod that also has higher levels of zinc would be AMSOIL Premium Protection 10w40.
https://www.amsoil.com/p/premium-pro...motor-oil-amo/
Also- here is a good write-up about the differences between racing oil and regular motor oil.
https://blog.amsoil.com/racing-oil-v...he-difference/
AMSOIL offers a Preferred Customer program that saves you 25% off MSRP and you get free shipping with orders over $100 along with other benefits too.
https://www.amsoil.com/offers/pc/
Another thing about pricing- Amsoil adjusted their prices three times in 2021 whereas their competitors did six or more times and usually by 10% or more.
This is a great website to learn more about whats happening within the lubricant industry;
https://jobbersworld.com/category/lubricant-news/
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-04-2022, 09:06 AM   #6
SCOTI
SCOTI's Avatar
I use 'Driven' racing oil w/the ZDDP additive.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-04-2022, 09:06 AM   #7
sick472
sick472's Avatar
I've been using the Rotella 15w-40 in my older V8 vehicles ('67 to '85) for several years now. 13k miles on one, 2k on another, and 20K on a well used 350 which has recently been rebuilt with 2k on it currently...so, not a lot of miles on any of them and no oil expertise on my part. It is said to have more zinc than most AND I like the way it smells, lol.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 01-04-2022, 09:39 AM   #8
ACS
Same. I buy it by the 5 gallon bucket and change it regularly with a quality filter.
ACS is offline   Reply With Quote
Old 01-04-2022, 11:29 AM   #9
fordguy40
Mobil 1 w/ZDDP. Goodwrench "base" 350.
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 01-04-2022, 11:40 AM   #10
72c20customcamper
72c20customcamper's Avatar
GTX classic high zinc it’s on the shelf at Walmart and my autozone
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-04-2022, 12:25 PM   #11
truckin 79
I use 10w-30 Walmart high mileage synthetic oil with a mobile-1 filter. I feel like the synthetic helps with less oil leaks and my engine has at least 164,000. I just use it as my junk yard hauler but have put a lot of miles to WY and Denver.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 01-04-2022, 12:51 PM   #12
MikeB
MikeB's Avatar
It's more than adequate, especially after the engine is broken in. I suspect stock engines with low pressure valve springs rarely experience wiped lobes with any kind of oil that's changed regularly. Breaking-in a new cam & lifters is a different story. I used Driven BR-30 for my last flat tappet engine break-in, then changed to VR1 after a few hundred miles.
Info on Driven BR-30:
The same high Zinc and Phosphorus formula as our original break-in oil, now in an SAE 5W-30 viscosity for modern OEM rebuilds and hydraulic lifter engines. Provides excellent ring sealing. Does not require additional ZDDP additives. Good for full power pulls on the dyno, one night of racing or up to 400 miles on the street. Viscosity typical of 5W-30.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-04-2022, 01:03 PM   #13
hatzie
Moderator
hatzie's Avatar
Any of the diesel oils with higher Zinc and Phosphorous content like Rotella T5 & T6, Mobile 1 TurboDiesel Truck, Chevron Delo, Mobil Delvac, and several others.
I run the higher zinc/phosphorus witches brews in my Aircooled engines.
Here's a ZDDP oil list.
https://www.autorestomod.com/oil-zddp-list.html
I would look up some recent virgin oil analysis sheets on BobIsTheOilGuy if you're really worried. Over 1200ppm are good numbers but over 1100 is pretty good. A lot of gasoline engine oils average 600-800ppm.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-05-2022, 08:37 AM   #14
Sabaka454
Sabaka454's Avatar
Just buy a case of this and drop one in at each oil change.
https://www.stp.com/products/oil-add.../oil-treatment
Sabaka454 is offline   Reply With Quote
Old 01-05-2022, 10:30 AM   #15
MikeB
MikeB's Avatar
It's better to buy oil with adequate levels of ZDDP so you don't overdo it with an additive, which can create other problems.
From Driven Oil: If you have too much ZDDP, you start to see corrosive wear and cause another problem. Adding an excess causes the oil to become acidic, and before you know, you’re wearing cams, bearings and bushings because of too much ZDDP.
The problem is you're flying blind if you don't know how much ZDDP is in the oil's additive package. I even recall an article by the makers of a ZDDP additive that describes how to calculate the proper amount of their product to add to a motor oil. That amount depends on how much ZDDP the oil already has.
By the way, STP is a "viscosity index modifier", in other words it thickens oil, which your engine may not need or even like. However, if you have an old engine with blow-by, low oil pressure, etc., then go for it! But I'd probably just start using 20W50 oil instead.
Mike
Old 01-05-2022, 07:35 PM   #16
Loco83
Loco83's Avatar
Been running Pennzoil 10w30 since forever and Fram/STP filters,no need for boutique high price oils, just change your oil regularly. 5K for me.
Loco83 is offline   Reply With Quote
Old 01-05-2022, 09:52 PM   #17
TALLone71
I use vr1, in all of my flat tappet engines, and on a new cam, a bottle of comp high zinc oil additive for the first 500 miles..and have seen good results with rotella too, at the shop where I work
TALLone71 is offline   Reply With Quote
Old 01-08-2022, 01:52 PM   #18
Axle
Axle's Avatar
Got my interest, until I looked it up and they do not offer it in a 10w30. I drive my truck in the winter, 20w50 and 15w40 isn't an option. Secondary rant; even here in the cold north seems nobody carries anything but 15w40 diesel oil.
Axle is offline   Reply With Quote
Old 01-08-2022, 04:11 PM   #19
hatzie
Moderator
hatzie's Avatar
Shell Rotella T6 is 5W40 here in the states.
Canadian Tire has 0W40 Shell Rotella T6 on their web page. I'd love to be able to buy that for my sled. Not sure if they stock it in the stores but you should be able to find it North of the border.
https://www.canadiantire.ca/en/pdp/s...-0287935p.html
Old 01-19-2022, 03:57 PM   #20
greenmtnboy
greenmtnboy's Avatar
Mobil1 15w50 has 1300ppm Zinc and is available at Wally World.
greenmtnboy is offline   Reply With Quote
Old 01-20-2022, 08:58 AM   #21
Corts60
Just here to tinker
Corts60's Avatar
Read carefully on the newer diesel oils. Delo 400 now has its LE version which stands for low emissions and they’ve removed a lot of the zinc.
Old 01-20-2022, 01:50 PM   #22
68post
I use HyperLube Zinc replacement additive.
It is a synthetic polymer ester that provides better protection than zddp, doesn't change the base oil's chemistry (won't harm catalytic converters either), and will even provide enough wear protection that you can drop to a lower weight grade.
I've stocked-up several 12oz bottles @ $9.62 ea and you only need 1 oz per oil qt.
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 01-20-2022, 02:32 PM   #23
Ziegelsteinfaust
1/2 a bottle of break in additive is a good option when proper oils are hard to come by.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-20-2022, 02:38 PM   #24
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i tend to use the semi synthetic high mileage Castrol oil
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-20-2022, 02:57 PM   #25
chris989
Lucas hot rod 10/30
https://lucasoil.com/products/hot-ro...w-30-motor-oil
chris989 is offline   Reply With Quote
