01-07-2022, 09:58 PM | #1 |
Gas pedal swap
I have a 70 blazer that I just put new power in. Still a small block but heads,valve covers and intake are making the mechanical linkage unworkable. I did a search on here and there was a fella making conversions for 71-72 style but it seems like he’s not around anymore. Has anyone done a swap that can steer me in the right direction? I found a 72 pedal in my shed full of parts so I guess I just need the brackets and cable.
01-07-2022, 10:19 PM | #2 |
low n' slo
Re: Gas pedal swap
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-07-2022, 10:35 PM | #3 |
Re: Gas pedal swap
Awesome. Thanks Kev. Just ordered one
01-07-2022, 11:42 PM | #4 |
low n' slo
Re: Gas pedal swap
yessir, glad to help
01-08-2022, 03:41 AM | #5 |
Re: Gas pedal swap
Here is a picture installed. Note: No drilling was required it goes through an existing hole. I believe the hole is originally for the rubber plug that retains the firewall insulation.
If you require a transmission kick down it can be installed on the bracket on the inside of the vehicle. They are a lot less expensive than the older ones attached to the carburetor. Don't forget to purchase a plug assortment to plug the original hole. + I used an aftermarket custom cable. Because of this I had to make an adapter where the cable went through, the eye on the end, to retain the end of the cable or it would just pull through. If using a stock cable this wouldn't be necessary. Last edited by Accelo; 01-08-2022 at 03:49 AM. |
