Old 01-08-2022, 07:42 PM   #1
Mbeef61
Mbeef61's Avatar
Qa1 install question
Have a question for those who installed their Qa1 coil overs. Prepping my frame for it before paint
In the rear… I know you remove the upper spring perches (circled in red) do you remove the other bracket there? (Circled in green) looks like a reinforcement bracket. Reason I ask is one side is already missing rivets. Do I need to remove, clean and reinstall with bolts? Or just remove? (Pics of the offending side also)
Mbeef61 is offline   Reply With Quote
Old 01-09-2022, 05:33 AM   #2
SIXTY9
Re: Qa1 install question
I installed the QA1 on my 69 and the stiffner will stay in place with no problem. IIRC you do have to remove one rivet to remove the shock mount to remove it.(both left and right side) I did replace them with a grade 8 bolt.
SIXTY9 is offline   Reply With Quote
