Old 01-09-2022, 07:24 AM   #1
Paul Y
Putting the cab on its back. Would this work?
Morning all,
A thinking out loud post that I would appreciate a little feedback on to make sure I am not completely mad.
I need to flip Woodys cab onto the back so I can gain access to the floors to ensure he has a rust feee bottom and then clean and protect.
I am lacking in man power so getting 6 or so willing bodies over to do it manually will probably not happen.
So. I have an engine crane….
If I was to lift the rear of the cab up and use blocks to create a pivot point that wasn’t the cab corners and then attach my engine crane to the lower most fender mounting points and lift… would that work without damaging anything?
I have 2 bodies to help stabilise and support along with a load of old tyres to place as shock absorbers.
Understand that as I lift everything will want to move back to will be doing outside the garage.
Any thoughts?
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 01-09-2022, 07:45 AM   #2
Grizz1963
Grizz1963's Avatar
Re: Putting the cab on its back. Would this work?
Originally Posted by Paul Y View Post
Morning all,
Any thoughts?
P.
Paul, I will give you a ring.
I rolled my cab back, alone, onto a foam mattress on the chassis when I did the floor, years ago.
It is a great way to work, and all the ribs protect it from kinking or bending.
Do it.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 01-09-2022, 08:07 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
All I had was a cherry picker. I used this method (post #8) - http://67-72chevytrucks.com/vboard/s...d.php?t=549819
Made it all from wood. Piece of cake.
Old 01-09-2022, 08:24 AM   #4
Grizz1963
Grizz1963's Avatar
Another we did when we removed our cabs.
Mate Martin and I went this route.
CLICK LINK.
https://youtu.be/LxcuePYK-8Q
I know Paul’s problem is slightly different, but it should work.
Old 01-09-2022, 05:54 PM   #5
Paul Y
Problem resolved. Just needed 3 old tyres and a bag full of rags!
P.
Woody's Build -
Old 01-12-2022, 01:45 PM   #6
66C10LB
I built a makeshift pallet for the front of the cab including slits for the inner fender connection points to protrude into. Then I used the cherry picker attached to a tightened ratchet strap and lifted the cab onto its nose. Made the pallet the right size to provide a nice pivot point.
66C10LB is offline   Reply With Quote
