Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-24-2021, 06:15 PM   #276
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Finished off the clutch linkage today. Original lower rod was shot and also was poorly lengthened. New rod from LMC was also too short. Cut it apart and welded in a 4" section of grade 8 bolt of a similar diameter. Came out pretty good. Also finished off the emergency brake cables. Finally got the correct length rear cables from Classic. The center cable was too long so it got shortened.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-27-2021, 09:33 PM   #277
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Still at it. Installed the spark plug heat shields, carburetor and sandblasted and painted the battery box, radiator clamps and hood latch assembly. Not sure what's next. Maybe install the interior wiring harness or restore the cluster.
Old 12-27-2021, 09:40 PM   #278
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Carb linkage
Old 12-27-2021, 10:32 PM   #279
LockDoc
The Older Generation
LockDoc's Avatar
Re: NJ Suburban
Looks good. Keep pluggin' away at it....
LockDoc
Leon
Old 12-27-2021, 11:19 PM   #280
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
LockDoc
Thanks Leon. I'm trying to figure out what can be done over the winter. Not sure if it's ok to put the wiring back in under the dash. The interior is painted already.
Old 12-28-2021, 12:54 PM   #281
LockDoc
LockDoc's Avatar
Re: NJ Suburban
It would certainly be easier to install the wiring before any of the dash components were installed. ie: Inst cluster, heater controls, radio, etc....
LockDoc
Leon
Old 12-29-2021, 05:06 PM   #282
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
LockDoc
Got it. The issue going around in the noggin here is that the truck hasn't been painted yet. On one hand it would be great to have the entire truck painted body color before doing the work under the dash. It's too cold to paint now so I'm trying to find things to work on during the winter. The inside of the truck has been painted already.
Old 12-29-2021, 10:43 PM   #283
LockDoc
LockDoc's Avatar
Re: NJ Suburban
That certainly limits you a little bit but I would just finish out the inside then. I have the same thing going on with my '70 Short Bed and I have been putting the interior parts in it.
LockDoc
Leon
Old 12-31-2021, 02:45 PM   #284
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: NJ Suburban
Paul
I would think you would want to completely tape up all the openings before painting the exterior otherwise you will have a lot of over spray inside the cabin area. if you do that you should have no issues with doing the wiring now if the inside is already painted.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 01-02-2022, 10:18 PM   #285
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Originally Posted by richard2717 View Post
Paul
Richard
Thanks Richard! I was bummed that I wouldn't have anything to work on over the winter.
Old 01-10-2022, 10:04 AM   #286
HO455
HO455's Avatar
Re: NJ Suburban
Are you going with a completely stock wiring harness?
If not have you considered using part of an A/C harness along with the bigger A/C blower motor for more heater output? It's just something I've been considering for mine.
It might be a good winter project.
RIP Bob Parks.
Old 01-10-2022, 04:01 PM   #287
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
A few months ago I repaired the original harness using the spare that came with my 68 parts truck to replace any bad sections. When this was my daily driver in the 80's trying to heat the entire truck was as useless as cooking thanksgiving dinner with a match. I used to hang a heavy blanket just behind the rear seat from roof to floor to keep the heat up front. This truck will be a summer driver though when finished so it wont see much need for a heater. Both of my 69 Cougars have rarely had need for the heater in the last 25 years. Thanks for the tip though!
Old 01-14-2022, 09:32 PM   #288
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
This weeks project: the cluster. Touched up the chrome with a silver paint pen, repainted the semi black, polished the lens (400-5000 grit then polish) and added a tach from a Camaro as outlined by Grincoloco in the truck forum. All I need is the needle paint and I can pack it up for when it's time to install it!
Old 01-15-2022, 11:50 AM   #289
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Looks great! I have a couple I need to do. I have all of the stuff, I just need to get off my duff and do it....
LockDoc
Leon
Old 01-15-2022, 01:31 PM   #290
HO455
HO455's Avatar
Re: NJ Suburban
That came out awesome! Good work!
RIP Bob Parks.
Old 01-17-2022, 10:12 PM   #291
kev2809
low n' slo
kev2809's Avatar
Re: NJ Suburban
same route I plan on going with. I too have all the stuff but too nervous to tear into it.
gauges look great btw
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-17-2022, 10:57 PM   #292
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Thanks!
It's not a really tough task to install the tach. Grincoloco has some good pics and tips on how to do it. What I had trouble with was cutting out the hole in the back of the gauges for the circuit board backing to stick through. It had to be enlarged a couple times to get the tach in position. Another problem was that the studs on the back of the gauge assembly stick out and interfere with the blue circuit board on the stock assembly. I wound up trimming the studs down even with top of the plastic covered attaching nuts and covered the ends with silicone. Drop me a line if you want any info.
Old 01-17-2022, 11:07 PM   #293
kev2809
low n' slo
kev2809's Avatar
Re: NJ Suburban
well I'm going a little further since I'm going ls. I'm doing the s10 speedo swap...the camaro tach...and swapping the ammeter guts to put in a volt meter. and, ditching the circuit board and making a wired harness. lol dreading the entire thing....
-_--_--_ _________
Old 01-18-2022, 07:02 PM   #294
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
That's a lot of work but all do-able. Take your time and it will work out. Grincoloco has a bit about doing the amp volt swap and it looks pretty straightforward. It might be something to do on my 70 since it may be years before the cluster is installed. Good luck and keep up the progress and updates in your build thread!
Old 01-19-2022, 10:22 AM   #295
HO455
HO455's Avatar
Re: NJ Suburban
I did the voltmeter conversion with square body guts. It was pretty straightforward and the only real challenge was getting the needle on the shaft in the right place so the meter showed 12 volts with the needle on the center mark of the old ampmeter face.
RIP Bob Parks.
Old 01-19-2022, 10:27 AM   #296
BigBird05
Re: NJ Suburban
How did that work out? Did you come up with away to do it or was it just trail and error.
BigBird05 is offline   Reply With Quote
Old 01-19-2022, 03:00 PM   #297
HO455
HO455's Avatar
Re: NJ Suburban
I used a variable power supply to get exactly 12.00 volts. Then it took 5 or 6 tries to get the needle in the correct orientation on the shaft. As I didn't see a good way to hold the shaft while pushing the needle on the shaft. I had to redo it as the shaft would move and the needle would not be where I wanted it. It took maybe 15 minutes to make it indicate satisfactory.
RIP Bob Parks.
Old 01-19-2022, 04:12 PM   #298
kev2809
low n' slo
kev2809's Avatar
Re: NJ Suburban
that's great idea
-_--_--_ _________
Old 02-06-2022, 01:00 AM   #299
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Tonight's project.
Old 02-06-2022, 10:17 PM   #300
LockDoc
LockDoc's Avatar
Re: NJ Suburban
I would like to try the voltmeter conversion on one of mine. I will have to read that again.
LockDoc
Leon
