01-10-2022, 06:23 PM | #1 |
Manual rack and pinion on my 65 stepside?
Does anyone know of a bolt on solution to the factory cross member on my 65 C10? Ive got extensive work done on my from suspension like front coil overs, drilled and slotted rotors on wilwood camero calipers etc so changing the front (k member as so many ppl call it) isn’t really an option for me
Posted via Mobile Device |
01-10-2022, 06:26 PM | #2 | |
01-10-2022, 06:33 PM | #3 |
Moderator
Re: Manual rack and pinion on my 65 stepside?
Have you tried No Limit? Theyre on this board.
01-11-2022, 07:36 PM | #4 |
x2. Not sure if a manual rack works w/the NoLimit set-up though.
POL has R&P kits for a factory x-member as well but they only say 'Power R&P' kits.
01-11-2022, 10:45 PM | #5 |
Moderator
