Clutch fork/linkage assembly questions
67 C20, 350 v8, 4sp.
As you can see by the picture, I don't have the right stuff, I have a piece of all thread that should be a threaded rod. So, I can buy a rod, and from pictures on the internet I also need what looks like a spacer wedge. Question: once I put the rod and spacer through the fork, what is on the other side of the fork? I mean, It has to allow it to pivot, so just a nut doesn't make sense in my head. Also, which hole in the fork? The small inner or the larger oblong outer? I also saw in another thread something about a long and short throw out bearing? My current one looks like a short, yet it could be wrong as I've got barely any pedal. I've got the 3 finger diaphragm. |
Re: Clutch fork/linkage assembly questions
Looking at the LMC website.. Here's a picture of the rod and related components.
https://www.lmctruck.com/1967-72-che...clutch-linkage |
I saw that, but doesn't anything attach to the other side of #3? And also which hole in the fork?
Nothing attaches to the other side. All components that make up the assembly are in the picture. Only thing left out is the fork itself. The rod and pushrod nut (wedge) goes in the outside hole. When the clutch freeplay is properly adjusted, everything stays in place.
You have the wrong pushrod.. It needs to have a "nub" on the end that fits into the fork. Your fork has a lot of wear in the area where it contacts the throwout bearing.. I'd suggest you replace it. |
#5 | |
I guess I'm using the wrong terminology, this is the clutch I have:
Also, thanks for the replys.
If I use the inner hole, will that engage/disengage the clutch faster? Less pedal travel? |
That's a Long (old school design reference) type clutch. Sometimes referred to heavy duty. I wouldn't suggest using the inner hole.. That makes for more bearing travel, stiffer pedal movement, and often leads to linkage binding.. "Faster" isn't a reason either..
It’s a borg and beck, not a long style.
With diaphragm clutches you have a flat finger (long tob) and a raised finger (short tob). Look here for rods, forks, springs etc. https://4speedconversions-com.3dcartstores.com/ |
#10 | |
Diaphragm clutches were the scourge of race cars in the '50s and early '60s. During a full throttle 8K RPM "speed shift", the diaphragm would turn wrong side out and the pedal would stick to the floor. Often times this resulted in a clutch, flywheel, or engine explosion. A friend of mine lost his right foot to one of those explosions. |
![]() Join Date: Aug 2019
the picture that you posted is of a pressure plate. The clutch disk is round and flat. Usually, 10 or 11 inches. The type of pressure plate that you are using determines which length of throw out bearing you will need.
Borg and beck is also a style.
As is a diaphragm and long style. And don’t forget the b&b/long style. They’re all recognized by their finger style, not by who makes them. |
#13 | |
![]() Join Date: Feb 2002
![]() Join Date: Nov 2015
This is the way my 72 C10 with 350 and sm465 4 speed was set up before I pulled everything for a Ls and T56 magnum.
Not sure if this set up was correct for stock, but maybe the pics will help.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
#15 |
The big spring is supposed to be hooked up on the frame rail up near the z-bar.
They way that one is would pull the tob onto the fingers all the time. |
#16 | |
Senior Moment
![]() Join Date: Mar 2002
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#17 |
![]() ![]() Join Date: Jan 2005
Here are the pivot ball and retaining spring for attaching the fork to the bellhousing. They're items 6 & 7 here:
https://www.lmctruck.com/1967-72-che...tch-components |
#18 |
Looks like you have that retaining nut too. Yours is the only one beside mine I've seen like it.
#19 |
Thanks everyone, also looks like I'm missing the retaining spring for the ball into the fork. Man, sometimes I wonder how this truck even worked with how messed up most things are on it.
