#276 |
Re: NJ Suburban
Finished off the clutch linkage today. Original lower rod was shot and also was poorly lengthened. New rod from LMC was also too short. Cut it apart and welded in a 4" section of grade 8 bolt of a similar diameter. Came out pretty good. Also finished off the emergency brake cables. Finally got the correct length rear cables from Classic. The center cable was too long so it got shortened.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
#277 |
Re: NJ Suburban
Still at it. Installed the spark plug heat shields, carburetor and sandblasted and painted the battery box, radiator clamps and hood latch assembly. Not sure what's next. Maybe install the interior wiring harness or restore the cluster.
#278 |
Re: NJ Suburban
Carb linkage
#279 |
The Older Generation
Re: NJ Suburban
Looks good. Keep pluggin' away at it.... ![]() LockDoc
#280 |
Re: NJ Suburban
Thanks Leon. I'm trying to figure out what can be done over the winter. Not sure if it's ok to put the wiring back in under the dash. The interior is painted already.
#281 | |
Re: NJ Suburban
It would certainly be easier to install the wiring before any of the dash components were installed. ie: Inst cluster, heater controls, radio, etc.... LockDoc
#282 |
Re: NJ Suburban
Got it. The issue going around in the noggin here is that the truck hasn't been painted yet. On one hand it would be great to have the entire truck painted body color before doing the work under the dash. It's too cold to paint now so I'm trying to find things to work on during the winter. The inside of the truck has been painted already.
#283 | |
Re: NJ Suburban
That certainly limits you a little bit but I would just finish out the inside then. I have the same thing going on with my '70 Short Bed and I have been putting the interior parts in it. LockDoc
#284 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: NJ Suburban
Paul
I would think you would want to completely tape up all the openings before painting the exterior otherwise you will have a lot of over spray inside the cabin area. if you do that you should have no issues with doing the wiring now if the inside is already painted. Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#285 | |
Re: NJ Suburban
#286 |
Re: NJ Suburban
Are you going with a completely stock wiring harness?
If not have you considered using part of an A/C harness along with the bigger A/C blower motor for more heater output? It's just something I've been considering for mine. It might be a good winter project.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#287 |
Re: NJ Suburban
A few months ago I repaired the original harness using the spare that came with my 68 parts truck to replace any bad sections. When this was my daily driver in the 80's trying to heat the entire truck was as useless as cooking thanksgiving dinner with a match. I used to hang a heavy blanket just behind the rear seat from roof to floor to keep the heat up front. This truck will be a summer driver though when finished so it wont see much need for a heater. Both of my 69 Cougars have rarely had need for the heater in the last 25 years. Thanks for the tip though!
#288 |
Re: NJ Suburban
This weeks project: the cluster. Touched up the chrome with a silver paint pen, repainted the semi black, polished the lens (400-5000 grit then polish) and added a tach from a Camaro as outlined by Grincoloco in the truck forum. All I need is the needle paint and I can pack it up for when it's time to install it!
#289 | |
Re: NJ Suburban
Looks great! I have a couple I need to do. I have all of the stuff, I just need to get off my duff and do it.... LockDoc
#290 |
Re: NJ Suburban
That came out awesome! Good work!
#291 |
low n' slo
![]() Join Date: Mar 2009
Re: NJ Suburban
same route I plan on going with. I too have all the stuff but too nervous to tear into it.
gauges look great btw
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#292 | |
Re: NJ Suburban
It's not a really tough task to install the tach. Grincoloco has some good pics and tips on how to do it. What I had trouble with was cutting out the hole in the back of the gauges for the circuit board backing to stick through. It had to be enlarged a couple times to get the tach in position. Another problem was that the studs on the back of the gauge assembly stick out and interfere with the blue circuit board on the stock assembly. I wound up trimming the studs down even with top of the plastic covered attaching nuts and covered the ends with silicone. Drop me a line if you want any info.
#293 |
low n' slo
Re: NJ Suburban
well I'm going a little further since I'm going ls. I'm doing the s10 speedo swap...the camaro tach...and swapping the ammeter guts to put in a volt meter. and, ditching the circuit board and making a wired harness. lol dreading the entire thing....
#294 |
Re: NJ Suburban
That's a lot of work but all do-able. Take your time and it will work out. Grincoloco has a bit about doing the amp volt swap and it looks pretty straightforward. It might be something to do on my 70 since it may be years before the cluster is installed. Good luck and keep up the progress and updates in your build thread!
#295 |
Re: NJ Suburban
I did the voltmeter conversion with square body guts. It was pretty straightforward and the only real challenge was getting the needle on the shaft in the right place so the meter showed 12 volts with the needle on the center mark of the old ampmeter face.
#296 |
![]() Join Date: Aug 2019
Re: NJ Suburban
How did that work out? Did you come up with away to do it or was it just trail and error.
#297 |
Re: NJ Suburban
I used a variable power supply to get exactly 12.00 volts. Then it took 5 or 6 tries to get the needle in the correct orientation on the shaft. As I didn't see a good way to hold the shaft while pushing the needle on the shaft. I had to redo it as the shaft would move and the needle would not be where I wanted it. It took maybe 15 minutes to make it indicate satisfactory.
#298 |
low n' slo
Re: NJ Suburban
that's great idea
#299 |
Re: NJ Suburban
Tonight's project.
#300 |
Re: NJ Suburban
I would like to try the voltmeter conversion on one of mine. I will have to read that again. LockDoc
| Bookmarks |
| Thread Tools | |
| Display Modes | |
