![]() Join Date: Jun 2021
700r4 to 205
Doing a 4spd to 700r4 conversion. Guy at advanced adapter s told me I just needed the tail shaft changed, which I did, and it will bolt right to the 4spd adapter...guess what.. it doesn't, the bolt pattern is totally different and the hub they provided is too deep What am I missing ?
70 c20 350 ![]() ![]()
![]() Join Date: Mar 2003
Re: 700r4 to 205
You need a factory T350 to 205 adapter. I may have a couple of them hidden in a box somewhere
Re: 700r4 to 205
Re: 700r4 to 205
Found one local thank you
All about them K’s
![]() Join Date: Jun 2014
Re: 700r4 to 205
The th350 and 465 205’s use different case input shafts and transmission output shafts as well. 10 spline course input and output on the 465 and 27 spline fine on the 350 if memory serves me. I believe there is a conversion coupler made that will make this swap work….
Here’s said coupler… https://www.offroaddesign.com/drive-...10-spline.html
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#6 | |
Re: 700r4 to 205
Re: 700r4 to 205
| Bookmarks |
| Thread Tools | |
| Display Modes | |
