Old 01-16-2022, 10:29 PM   #1
Ziegelsteinfaust
Steering columns
I have a 91 suburban tilt column in my 83 rcsb C10. Well at the Pomona swap meet I got a 79 regular column to put in to get rid of the stalk with controls that are on my dash.
Well the keyed slider moves the opposite way on the early model vs the late one. The early one pulls the slider up, and the later pushes it down.
Did I do something wrong or is this how they operate?
Ziegelsteinfaust is offline   Reply With Quote
Old 01-16-2022, 11:03 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Steering columns
IIRC 1983 is an oddball orphan as far as the column goes. The dimmer is on the column in 1983 and not a floor button anymore. The wipers are on the dash in 1983.
If you intend to run a 1979-82 column in your truck then you'll need to wire in a dimmer button on the floor.
As long as the 1979 ignition switch down on the column tube plugs into the 1983 cab harness you should be good to go on the ignition.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-16-2022, 11:08 PM   #3
Ziegelsteinfaust
My 83 has the dimmer on the floor. So maybe it is a early build
Old 01-16-2022, 11:14 PM   #4
hatzie
Moderator
hatzie's Avatar
They did some odd stuff in 1983. Not impossible that it's an early vs late build thing.
Old 01-16-2022, 11:44 PM   #5
ray_mcavoy
That's normal and the difference is due to the regular vs. tilt column (not the year).
It results in a different ignition switch being used for the regular vs. tilt column as well. They usually take the same connectors though, but you have to twist the wiring around a bit since the orientation of the connectors is flipped around.
ray_mcavoy is offline   Reply With Quote
