Old 01-17-2022, 12:25 PM   #1
MARKDTN
Delay Wipers-use Ford switch and module?
I have read a bunch on adding delay wipers. I can't seem to find a definitive answer. I recently made a '66 Mustang have delay wipers by using a 1980 switch and delay module from an F150. Common bolt-on mod for early Mustangs. But it got me thinking, both Ford and 67-72s seem to use a 2 speed non-recessed-park wiper motor. Both seem to switch the ground. Has anyone tried using a Ford switch and delay module with a 67-72 motor? The F150 switch I got had a long "D" shaped shaft that I cut off in the Mustang, so I think it could work with the stock knob with a little work.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-17-2022, 06:07 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Delay Wipers-use Ford switch and module?
That is what I was thinking of trying when I get to that point.
I remember years ago working on a 1980 F__D truck.
And it had a System that I thought might just work.
Subbed to see what you find out
84 Chevy K-20
Old 01-17-2022, 06:39 PM   #3
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Interesting ... 68Bowtie4x4 in the parts forum that is getting ready to make a box thing.
Which I have signed up for but if this thing works and you can't tell from the outside you have a FORD part in your truck, then this solution must be better than a box and a added switch.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-17-2022, 07:04 PM   #4
Getter-Done
Here is the concept of the idea in the picture & e Bay link below.
I would have to sit down and go thru the wiring again.
It's only been a (FEW) years since I have messed with it.
It will work.
I am just juggling about 20 Projects right now
Link: https://www.ebay.com/itm/38369152330...3460d0eab1b17a
84 Chevy K-20
Old 01-19-2022, 10:27 AM   #5
MARKDTN
Exactly! On the Mustang you just unplug from the back of the original switch and plug that in. It is a bolt-on. You could either cut the plug off or get a Ford plug and splice it in. I don't see why it won't work-and almost more importantly-use the 67-72 wiper motor.
I got mine from the pick-a-part for $20 I think. Way less than that $119 on Ebay. I think the switch and delay module are 74-86 Ford trucks. The delay module may also come from other applications, but I don't know that.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-19-2022, 11:04 AM   #6
BigBird05
How does the washer function work on the ford switch? Could the delay box be made to work with the 72 chevy switch?
BigBird05 is offline   Reply With Quote
Old 01-21-2022, 10:48 AM   #7
MARKDTN
It has a spade terminal that goes hot when you push the switch in so simple to hook up to a separate wiper pump/bottle.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-21-2022, 11:37 AM   #8
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Here is a YouTube, it's all about doing this on a Ford but talks about the switch and connector a bit. You can also see how the washer works (and points out which wire it is that goes hot).
I also been looking for a Ford Wiper Switch/Motor diagram but so far this is the only one I been able to find (image attached). It is user created but it seems it is switching power from Off, Low, High.
Chevy 67~72 Wiper/Switch Diagram - Wipers on/speed ground driven.
Richard
Old 01-21-2022, 11:57 AM   #9
Grumpy old man
Grumpy old man's Avatar
Here is another option .
https://67-72chevytrucks.com/vboard/...d.php?t=801366
Old 01-21-2022, 12:27 PM   #10
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Well heck, that seems to be a better deal there
HO455's Post on the install
Revolutionelectronics
Richard
Old 01-21-2022, 02:31 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
Could use a peterbilt one
https://www.ebay.com/itm/WIPER-SWITC...-127632-2357-0
Old 01-21-2022, 09:45 PM   #12
lutronjim
The video showed off,low & high. How does the switch control delay?
lutronjim is offline   Reply With Quote
Old 01-28-2022, 06:55 PM   #13
lutronjim
MARKDTN
I found A wiring diagram for a 1978 Bronco which is supposed to be same as F150. The diagram seems to indicatate that the wiper motor is grounded and requires 12v+ to run. Course I could be reading wrong. Although a couple of relays would solve.
https://www.supermotors.net/getfile/1032656/fullsize/1979-bronco-f100-through-f350_page_37.jpg[/img]
Old 01-28-2022, 07:01 PM   #14
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
here it is an attachment
Richard
Old 01-28-2022, 09:56 PM   #15
HO455
HO455's Avatar
When you turn the wiper switch from off to low the wiper does one sweep and delays about 6 seconds.
Turn the switch to high and back to low and the wipers will sweep and delay about 3 seconds.
Turn the switch to high and back again and the delay will about 1.5 seconds.
Turn the switch again and the wipers will operate without delay in slow speed.
Turn the switch from off to high and the wipers operate in high speed as normal.
To go from off to slow with no delay turn switch to high and once the wipers start to operate turn switch to slow and they will operate in slow with no delay.
If your in slow and want to have a delay turn the switch to off and back and you will have minimum delay.
Another turn to off and back and you would have the 3 second delay.
It sounds a bit complicated but in real life I don't even think about it when I use the wipers.
RIP Bob Parks.
