Old 01-21-2022, 11:15 PM   #826
Low Elco
Re: SkinnyG's '61 Apache
After several years at WFO, I'm in the same position. This year was lining up to be calmer, but they're beating on the door. Trying to learn to relax, is not relaxing.
Low Elco is offline   Reply With Quote
Old 01-29-2022, 07:46 PM   #827
SkinnyG
SkinnyG's Avatar
I finally started digging into the rad support. Rusty nasty bottoms were cut out, and I blasted until I ran out of sand.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-29-2022, 07:49 PM   #828
SkinnyG
SkinnyG's Avatar
And for giggles, I finally finished these signs:
Old 01-30-2022, 09:58 PM   #829
SkinnyG
SkinnyG's Avatar
Old 01-30-2022, 11:31 PM   #830
cwcarpenter98
cwcarpenter98's Avatar
The new signs look great up there. Now you just need a Chevy bowtie to complement them!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-30-2022, 11:36 PM   #831
SkinnyG
SkinnyG's Avatar
Surprisingly, while I have owned more GMs than anything, I am not a Chevy fan at all.
(grin)
Old 02-01-2022, 12:14 AM   #832
SkinnyG
SkinnyG's Avatar
Primered. I'll let it cure for a week before welding in the patches.
Old 02-06-2022, 11:55 PM   #833
SkinnyG
SkinnyG's Avatar
Patches welded in:
Next patches formed:
And primed, to cure for another week (you can see the shifter arm and the proportioning valve mount here as well):
Old 02-07-2022, 01:14 AM   #834
350TacoZilla
Odd, I'm not able to see any pics for last couple pages but no problems earlier in build. Also not showing me any kind of error or large un-used portion of the box, just shows your comments like thats all that's there.
350TacoZilla is offline   Reply With Quote
Old 02-07-2022, 01:36 AM   #835
SkinnyG
SkinnyG's Avatar
Odd.
Click this link and see if the image shows up.
https://www.gwellwood.com/wordpress/...33-672x378.jpg
Old 02-07-2022, 10:27 AM   #836
SCOTI
SCOTI's Avatar
I'm still seeing older & current images w/o issue.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-14-2022, 02:21 AM   #837
SkinnyG
SkinnyG's Avatar
All this was primed, then welded in:
Also making changes to my solvent tank, which dissolved its second pump. Bought a skookum pump which will now be held in a translucent bucket, pumped up to the tank, and drained back into the bucket.
Old 02-21-2022, 11:28 PM   #838
SkinnyG
SkinnyG's Avatar
Inner fenders mounted so I could tweak the door-to-fender gaps.
Not perfect, but if you aim for perfection, you'll never get it finished; Chevy aimed low, I can too.
Handy to use studs to hang the fender when you know you're going to take them on and off repeatedly:
Also made a bit to my home-made slide hammer to pull door and fender edges into alignment with each other.
Old 02-22-2022, 12:39 AM   #839
cwcarpenter98
I like that slide hammer. Have you done a video or explanation in the past on what you did to make it?
Christian Carpenter
Old 02-22-2022, 12:45 AM   #840
SkinnyG
SkinnyG's Avatar
No. It's pretty simple.
1/2" rod, threaded UNF on either end.
Handle is SCH40 pipe with a UNF nut welded in it.
Hammer is 1.5" solid round.
The "hook" is a piece of scrap 3/16" flat bar I beat to a 90° in a vice, welded to a UNF nut. 1/8" would be better as it would slip in through the gap easier.
You can buy these. I just make a lot of my tools.
Old 02-22-2022, 12:57 AM   #841
SkinnyG
SkinnyG's Avatar
I made the slide hammer when I was trying to fix the crushed roof in my '77. I merely made this tip today.
Old 02-22-2022, 12:58 AM   #842
cwcarpenter98
Thank you! Sometimes it's more fun to make something useful rather than just going out and buying it
Christian Carpenter
Old 02-22-2022, 01:21 AM   #843
SkinnyG
SkinnyG's Avatar
Builds skill, too!
Old 02-27-2022, 08:58 PM   #844
SkinnyG
SkinnyG's Avatar
And just tried a bit of blocking on the walnut bag fender to see what would happen. This looks promising. Could build this up pretty easily with just more epoxy primer.
Old 03-06-2022, 01:36 PM   #845
SkinnyG
SkinnyG's Avatar
Things are progressing too slowly.
I recently bought a Hyundai Accent to daily drive (36mpg) instead of my C10 (10mpg). Our gas (premium, because 11:1) is $1.99/L, that's $5.50US/USgallon to you 'Muricans and £5.50/IMPgallon in the UK. The car will pay itself off in less than a year in savings alone. AND help me financially finish the '61.
Pops took a tumble recently, the second of significance, and that, coupled with a few other things has me looking for a care home for him as he's rapidly becoming unable to care for himself. My goal was to have the interior painted over Spring Break, but we'll see what happens.
If I have to choose between focusing on the truck or helping my pops, I have to choose my pops.
I'll keep you updated when I'm back on the truck.
Old 03-06-2022, 02:14 PM   #846
cwcarpenter98
I would make the same choice if I was in your situation. Take care of your pops, we'll be here when you're ready to get back on the truck
Christian Carpenter
Old 03-06-2022, 05:06 PM   #847
350TacoZilla
x2! take care man, the truck will always be there.
Old 03-09-2022, 03:02 PM   #848
aggie91
I'm just glad to be here!
aggie91's Avatar
Family first. My Dad just turned 80 in January and still gets along well and my Mom is 78, but I am not looking forward to dealing with putting them in an assisted living when the time comes to that.
Take care of him, the truck will still be there later.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-02-2022, 12:37 PM   #849
SkinnyG
SkinnyG's Avatar
A bit of an update. I've puttered a bit with the truck, but also been distracting myself modifying the Hyundai I bought to avoid gas prices.
Old 04-04-2022, 02:02 AM   #850
SkinnyG
SkinnyG's Avatar
Began spraying the interior this afternoon.
While I am using a new charcoal mask and a relatively ventilated area, I'm not McLoving it. I already have asthma; this ain't making it better.
I ordered a supplied air system.
