Old 01-14-2022, 11:44 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
LockDoc's "Low Budget", "Low Maintenance" Project Thread
I have been working on cleaning the shop for the last 2 months but I have had some delays. I finally got it cleaned out enough to get this truck inside so I will go ahead and start a thread on it.. This project is for all of the guys and gals that don't need a show truck but want something different to drive. Hence the "Low Budget". "Low Maintenance" part.
I am starting a new project. It won't be a quick assembly and it certainly won't be a show truck. It will be a new adventure for me. I'm usually pretty much by the book, but this build will be completely the opposite. I have this pretty nice '72 GMC 3/4 ton leaf spring frame and '71 cab & bed that I need to use. I didn't want to post anything until I knew I was going to have time to actually work on it over the winter but I started working on it outside last fall. I will still only be posting what I have done bit by bit instead of all at once.
LockDoc
Leon
Old 01-14-2022, 11:51 PM   #2
LockDoc
LockDoc's Avatar
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
I Pulled the bed off of the truck a day or two ago and I removed the cab today. They were just sitting loose on there so they didn't have to sit on the ground. I removed the Small Block frame brackets, and the bell housing cross member is next.
LockDoc
Leon
Old 01-14-2022, 11:55 PM   #3
Getter-Done
Getter-Done's Avatar
I Am in for the Build
Are those Vintage Green bean cans on the exhaust?
The early bird gets the worm,
85 Chevy K-20
Old 01-15-2022, 12:22 PM   #4
CG
BlahBlahBlah
Oh boy, I know where this is going and look forward to your updates.
Old 01-15-2022, 12:29 PM   #5
raggedjim
raggedjim's Avatar
Man, it would be a great time to go ahead and rebuild the front suspension. And maybe cleanup and paint the frame.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 01-15-2022, 02:07 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice project Leon. I know you have been waiting for this for a while.
Ryan
1969 Chevy milk truck
Old 01-15-2022, 02:37 PM   #7
LockDoc
LockDoc's Avatar
One is Green Beans and the other is Sauerkraut...
Cheater.
Good luck, Rg
Good Idea. Thanks!
A few years, yes.
LockDoc
Leon
Old 01-15-2022, 02:49 PM   #8
57taskforce
All about them K’s
57taskforce's Avatar
I like cheap and not as aesthetically pleasing to the eyes
Tyler
Old 01-15-2022, 04:04 PM   #9
LockDoc
LockDoc's Avatar
Got the bell housing cross member out and the new engine frame brackets installed. I need to remove the stock exhaust system and brackets next.
LockDoc
Leon
Old 01-16-2022, 02:58 PM   #10
LockDoc
LockDoc's Avatar
Removed the exhaust system and worked on the rear axle a bit trying to figure out how I want to set it up. I think I can use the stock '72 leaf spring hangers on the front end and just make some rear shackle brackets to get the results I need..
LockDoc
Leon
Old 01-16-2022, 03:26 PM   #11
MySons68C20
MySons68C20's Avatar
Love the pics of the big breaker bar and torch! Keep em coming!
MySons68C20 is offline   Reply With Quote
Old 01-16-2022, 03:29 PM   #12
Very kool. In to see what ya do with this one.
Old 01-16-2022, 07:54 PM   #13
68Gold/white
Leon, Job well done!!!
I see 72 big block mounts.....Is it getting a big block or a small block, using the "better" big block mounts? (I plan to do such on my 67).
Jeff
68Gold/white is offline   Reply With Quote
Old 01-16-2022, 08:10 PM   #14
68Gold/white
Do you know how to tell which can was green beans and which can was sauerkraut????
The smell
Old 01-16-2022, 08:25 PM   #15
Getter-Done
The smell
I remains long after
85 Chevy K-20
Old 01-18-2022, 02:43 PM   #16
LockDoc
LockDoc's Avatar
Jeff
The answer will be in one of my updates coming up...
LockDoc
Leon
Old 01-18-2022, 02:44 PM   #17
LockDoc
LockDoc's Avatar
The smell
It remains long after
The Kraut comes in a smaller can. They don't think the consumer will notice...
LockDoc
Leon
Old 01-18-2022, 02:49 PM   #18
LockDoc
LockDoc's Avatar
Worked on replacing the front spindles today. It was a bolt in deal and worked out great. Disk brake assemblies were off of a '77 C30 truck. Don't make fun of my Rube Goldberg jack setup...
LockDoc
Leon
Old 01-19-2022, 11:30 AM   #19
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Dually?....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-19-2022, 07:07 PM   #20
LockDoc
LockDoc's Avatar
I'm already going to have a little delay because I have some volunteer work to do at the local Historical Society building for the next couple of days. I need to put some display cases together for them.
LockDoc
Leon
Old 01-22-2022, 11:15 PM   #21
LockDoc
LockDoc's Avatar
Worked on cleaning up the frame a little and pressure washed it so I can spray it with Rust -Oleum satin black in a day or so. My heavy duty pressure washer is a gas powered unit and when I wash something like this frame it almost looks like you are sand blasting it. It still has a thin layer of rust but that is what Rust-Oleum paint is for, right? That makes it "Close Enough"....
Leon
Old 01-23-2022, 12:36 AM   #22
68Gold/white
Leon, you can buy that POR-15 paint in spray cans. It’s a little pricey, but it’s some awesome stuff!!!
Old 01-23-2022, 12:47 PM   #23
LockDoc
LockDoc's Avatar
I guess I didn't realize it was available in spray cans. Thanks.
LockDoc
Leon
Old 01-23-2022, 11:44 PM   #24
LockDoc
LockDoc's Avatar
I worked on the rear frame spring hangers. The original brackets were hard to cut on an angle so one spacer had to be a 1/16" thicker than the other. I finished them up and bolted them on.
LockDoc
Leon
Old 01-24-2022, 01:56 AM   #25
Ol Blue K20
Leon, you haven't answered my question yet...the suspense is killing me..dually?
Dale
