Old 01-23-2022, 05:40 PM   #1
USNavyTexan
Death Wobble
I just did a ls swap on my k20 72 4wd suburban. Before the swap I did not have the death wobble. After the swap and replacing all shocks with Rancho 9000xls (which I've tried adjusting them between 5-9) I've had the death wobble. Any ideas or help on what to do is very much appreciated!
USNavyTexan is offline   Reply With Quote
Old 01-23-2022, 08:21 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Death Wobble
What engine/trans did it have in it before?
Have you had it aligned at all? I wonder if it was on the verge of doing it before and the engine swap or new shocks changed something just enough to kick it over the edge.
LockDopc
Leon
Old 01-23-2022, 10:54 PM   #3
Richard
Re: Death Wobble
Would check front ball joints and wheel bearings for play with no weight on the tires. With tires on ground have someone move steering wheel back and forth to check drag link and tie rod ends. Also check steering box for play or any movement and frame for any cracks at mounting points. Another point to inspect is the spring bushings.
Richard
Old 01-23-2022, 10:58 PM   #4
bluek5
bluek5's Avatar
Re: Death Wobble
This, and do you have a steering stabilizer?
bluek5 is offline   Reply With Quote
Old 01-24-2022, 05:05 PM   #5
vectorit
What?
vectorit's Avatar
Re: Death Wobble
X2
Being that you had your engine out, the reduced weight on the front suspension may have caused an already wore out component to finally fail after getting the new engine installed.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
