Old 01-24-2022, 03:00 PM   #1
SD69C10
SD69C10's Avatar
Help with Rear Axle Housing
I purchased a rear disc brake kit from MPB and was trying to install it this weekend. The rear end axle housing currently on my 1969 C10 is what's in the picture and has a 12 bolt main. The instructions show that I should have a 4 bolt flange. Can anyone help me with what I have so I can try and track down the correct kit?
1966 Ford Mustang
1969 Chevy C10
1971 Chevy C20
SD69C10 is offline   Reply With Quote
Old 01-24-2022, 04:27 PM   #2
Accelo
Accelo's Avatar
Re: Help with Rear Axle Housing
You may have a transplanted housing. Am I correct in saying the brake backing plate is welded to the housing? May be you have a correct kit and an incorrect differential housing. How about a picture of the differential? May help sort this out.
Accelo is offline   Reply With Quote
Old 01-24-2022, 04:31 PM   #3
SD69C10
SD69C10's Avatar
Thank you @accelo....yep after doing some research it looks like I have a 12 bolt from a 63 C10. The info I found was that year was the only year the backing plate was press fit on.
1966 Ford Mustang
1969 Chevy C10
1971 Chevy C20
Old 01-24-2022, 04:46 PM   #4
BigBird05
You should be able to read the axle code from the bottom or front of the RH axle tube. That would tell you the year and gear ratio.
BigBird05 is offline   Reply With Quote
