#151 |
At the body shop.
Re: 2wd swap
Love when new parts require more new parts.
Our camaro calipers won't clear our American racing wheels. Rocket racing says theirs do. Any one have experience with them. I notice it's a holley brand now. At $550+ I'd like some 1st hand experience
" That didnt make it any newer " " Dont antique the equipment " |
#152 | |
Re: 2wd swap
The Rockets do offer greater caliper clearance but I've seen guys run spacers on them as well. What exact calipers/rotor combo? That's the bad thing about the 'big brake' set-ups from late model cars (or aftermarkets sources) they're mainly designed w/a bunch of pad offset required to clear fat/long calipers. Old school wheels don't have the same wheel center/barrel shape which helps.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-24-2022 at 10:27 PM. |
#153 |
At the body shop.
Re: 2wd swap
American racing Rodder
10 spoke 20x9.5 and x8 With a ss camaro brembo caliper. Would need at least a 3/4" spacer. Of 2 wheel companies I emailed only rocket responded. Said their attack wheel has 1.9 inches of caliper room. The other option is baller stuff. 5k+ in wheels or 5k brakes isn't in this blazer project.
#154 | |
Re: 2wd swap
2018 Z51 Vette rotor I'll ask for 100% verification but don't believe he's running a spacer:
#155 | |
At the body shop.
Re: 2wd swap
You know if those are 20s?
#156 |
Re: 2wd swap
They are 18x9's. I would think 20's would clear w/o issue. You could always order 'off the shelf' from Summit to test the fit for clearance.
As long as they aren't scratched, dinged, or have tires put on them, they're returnable if there's an issue.
#157 |
At the body shop.
Re: 2wd swap
Forward progress.
After 3 machine shops that didn't want my money we did it ourselves. Big brakes are fun they say
#158 |
Re: 2wd swap
No one would cut the hubs from your rotors?
#159 |
At the body shop.
Re: 2wd swap
No.
Got one I'm to busy And this... I never asked for a price. And also open up the i.d of the camaro rotor 2.700 to 3.065
#160 |
At the body shop.
Re: 2wd swap
And i was 2.5 hours into it not knowing what I was doing or been near a lathe in 20+ years
#161 |
Re: 2wd swap
For my g-body Malibu, I opted for aftermarket alum hubs for similar reasons.
First, just being able to find someone that would do the work & even then I prob would have spent the same amount for older, heavier, iron hubs. I also went w/the billet hubs because for my app they were machined for the heavier-duty Camaro 1Le outer bearing vs stock. Win/win. I have KORE3 C10 billet hubs but I've had them since '06 when I helped him w/the C10 brake package he offers. Not sure what he gets for them these days.
#162 |
At the body shop.
Re: 2wd swap
After jumping thru these hoops I see why people buy this stuff instead of fabricating it.
Although teaching my kid these lessons now may save him headaches in the future.
#163 |
At the body shop.
Re: 2wd swap
Wheels came.
Calipers need about .100 thou though :/ kid wanted the 18" so we did those. But the rotor looks awesome in the barrel
#164 |
Re: 2wd swap
Planning a .125" spacer then?
#165 |
At the body shop.
Re: 2wd swap
If I can find a steel one.
I'm going by the kids measurements. Haven't actually seen them yet. Work keeps getting in the way of playing with the toys. I see a wilwood makes a .196 in 5x5 I haven't looked much further yet.
#166 |
Re: 2wd swap
Send Cut Send.
They can pop you out a set of spacers in the numbers you want within given material sizes. They did a set for my Model-A pretty quick & very decent price.
#167 |
At the body shop.
Re: 2wd swap
Good to know.
#168 |
At the body shop.
Re: 2wd swap
Also reminded me we have a local cnc plasma guy local
#169 |
At the body shop.
Re: 2wd swap
Hay SCOTI, what hub did you use?
Went to pound stud thru ours last night and split the old rotor hub next to the stud. Insert unhappy guy
#170 | |
Re: 2wd swap
I heard of the g-body guys have the same/common issue after milling their hubs. Trick is to do the studs before & minimize the dimensions for the press fit (some guys were using too large of a knurl). I also verified the 18x8 Rocket cleared a C6 caliper & Z51 13.4" rotor. A buddy of mine said Weld Wheels is making a cheaper cast/flow-formed line of wheels. I looked them up but the BS options were limited vs. the Rockets.
#171 |
At the body shop.
Re: 2wd swap
We took .200 too much off.
Or .400 total. The knurl was wrong by a couple thou And also learned the snout of the hub gets into the wheel center. Gonna buy a new rotor and try again. The kore3 is based around corvette stuff, I don't know if our camaro stuff is the same
#172 |
At the body shop.
Re: 2wd swap
Also our cast iron hub snout doesn't fit thru the wheel center.
And won't fit without a 3/8 spacer. The snout and caliper hit.
#173 | |
Re: 2wd swap
#174 |
At the body shop.
Re: 2wd swap
Motivation has been lacking, but redo X2.
Also since finding our right quarter is junk, we have rounded up another and that's next.
#175 |
At the body shop.
Re: 2wd swap
Not for our k5 but my brother's stepper
