Old 07-24-2004, 03:41 PM   #1
palallin
'69 K-10 Dana 44 Help
Hi, guys.
I've been out of the loop for over six months, now--my mother died; my wife left my son and I, and we divorced, so I've been very busy (and poor).
Anyway, I need some advice on my front end. My truck has the closed-knuckle Dann 44. Lately, it has developed a distinct "clunk" when I turn sharply while at a standstill or moving very slowly. It seems to be on the left-hand side.
There is no obvious looseness in any extenal part of the steering, and, thanks to weather, I haven't had time to jack the thing up and look for play at the wheel hub.
Questions: Does anyone have an idea of what I need to look for when I finally do get under the truck? Is this likely internal to the big ball joint? There's a U-joint in there, right?
Does anyone have a source for parts, should replacement of something major become necessary.
Additional problems: when the ex went in search of greener pastures, she took my other transportation, so I cannot afford a great deal of down time.
(For breadth of coverage, I am posting a similar topic in the 67-72 board.)
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 07-24-2004, 06:30 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Is this with the front locked in and in 4wd? Or just driving in 2wd?
Hope your hanging in there. Have not lost my mother but been there with the wife, which in it's self is bad enough.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-24-2004, 07:24 PM   #3
palallin
HI, Jim.
No, just in 2WD, hubs unlocked.
(Hanging, sometimes by a noose, but hanging. There are still pratical matters to settle, but the legal stuff is over, and I'm looking to the future now.)
Old 07-24-2004, 10:12 PM   #4
Budweis
Geared for Collision
Budweis's Avatar
sounds like ball joints to me just pry up under wheel while raised off ground with pipe or something and look at play. you can get parts from board vendors, i bought most of mine in last few weeks here http://www.chevyduty.com/
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 07-24-2004, 10:36 PM   #5
palallin
Ummm, what ball joints?
Old 07-25-2004, 04:08 AM   #6
Budweis
Budweis's Avatar
my bad, my 70 44 has ball joints on the front guess your 69 don't.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 07-25-2004, 01:42 PM   #7
1969 GMC
1969 GMC's Avatar
it should have ball joints...mine does.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-25-2004, 04:15 PM   #8
palallin
No ball joints like 2wd: the whole sterring knuckle-kingpin assembly is a giant ball joint, as it were.
Old 07-25-2004, 07:49 PM   #9
Budweis
Budweis's Avatar
could you post a pic please? heres a pic of what my upper ball joint looked like.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 07-25-2004, 08:15 PM   #10
palallin
No pic and no way to take one right now, but I'll try to explain.
You see the open area between the upper and lower ball joints on your axle? That is ALL enclosed in a big, two-part metal ball knuckle on the closed-knuckle axles (hence the term "closed"). None of that area is open, and the u-joint rides in a bath of grease (85W-140). There ARE upper and lower "spindle/bearing pairs" (the service manual calls the steering knuckle bearings and cups), but they are more of a split kingpin than ball joints as there is no flex that ball joints provide.
I suppose I need to engage the hubs and see if the clunking is worse. If it is, I suspect the u-joint is going. I'd rather tha than there be a break in the knuckle itself. . . .
Old 07-25-2004, 10:04 PM   #11
Budweis
Budweis's Avatar
yeah i understand what your saying seen similar setups on fords i just didnt know they came on our trucks as ive never seen kingpin setup on one of our trucks yet. guess you learn something new everyday. good luck let us know what you figure out
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 07-25-2004, 10:42 PM   #12
1969 GMC
1969 GMC's Avatar
Oops, my bad...my axle is going into the trash as soon as it comes out from under the truck, I saw the castle nut and assumed ball joint. I guess you learn something new every day!
1969 GMC K2500
1996 Honda Accord
Old 07-26-2004, 07:34 AM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Check your front bearings. Then the king pins.
Old 07-26-2004, 11:19 AM   #14
palallin
Yeah, the more I look in the manual, the more I wonder about those kingpins. I'm pretty sure I can find bearings, but the pins themselves sceer me.
Old 07-29-2004, 11:47 AM   #15
palallin
Well, the clunk has gone away, though I will still check into the bearings and so forth. It's just strange that the clunk has not reappeared for almost a week.
Old 08-02-2004, 12:42 PM   #16
palallin
Does anyone know the torque specs on the caps that hold the pins/bearings in the knuckle? I want to pull them to check the bearins, but I don't want to unbolt anything till I'm sure I know how to get it all back together (no alternate ride).
