Old 01-26-2022, 03:13 PM   #1
suburban99
suburban99's Avatar
50 GMC s10 what works/looks good for wheels?
50 GMC on a S10 ls swapped. What size wheels and tires? 14-15? I have a 4x4 rear end installed and will use 2" spacers in front. On a budget..
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 01-26-2022, 07:25 PM   #2
mr48chev
mr48chev's Avatar
Re: 50 GMC s10 what works/looks good for wheels?
Anything that isn't gaudy and doesn't overpower the truck and make it look like the background for a rim add.
Simply meaning that first, they and the tires have to fit the total build plan and not be the first thing that your eye is drawn to. The whole build should follow that plan, though. If you see a part before you see the total truck, that part is probably wrong for that build.
Old 01-26-2022, 07:32 PM   #3
joedoh
joedoh's Avatar
15" rallies are perpetually for sale it seems, find a nice set of 8's or a set of 7 fronts and 8 rears and put some 215/75 front and 235/75 rear on them. search for "smoothies" or "reverse" and you can usually find a set of four under $200, then add tires. I have used steel wheels with poverty caps too. if you click my name and then click my photo albums you can see the various wheels I have used over the last 7 years.
useta be I could get a brand new set of artilleries and a set of coker whitewalls from jegs for around $1300 but now I think its around 2k.
