Old 01-24-2022, 10:47 AM   #26
LockDoc
The Older Generation
LockDoc's Avatar
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
Originally Posted by Ol Blue K20 View Post
Leon, you haven't answered my question yet...the suspense is killing me..dually?
You will get your answer tonight or tomorrow morning.....
LockDoc
Leon
Old 01-24-2022, 11:09 AM   #27
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
LockDoc
ok, I'll keep myself entertained for now....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-24-2022, 11:51 AM   #28
68Gold/white
Read post 13...........You will HAVE to wait also
68Gold/white is offline   Reply With Quote
Old 01-24-2022, 11:58 PM   #29
LockDoc
LockDoc's Avatar
Finished spraying the frame today. I have some touch-up to do on it but it came out pretty good.
Now to get the engine and transmission set down in it.
LockDoc
Leon
Old 01-25-2022, 03:20 AM   #30
Low Elco
Can't wait to see where it goes, Leon. Hope you and Pat are well.
Low Elco is offline   Reply With Quote
Old 01-25-2022, 05:19 AM   #31
Ol Blue K20
My question has been answered.... Looking good!
Dale
Old 01-25-2022, 12:05 PM   #32
CG
BlahBlahBlah
My guess is you didn’t want the stiffness of a one ton in back, but could you have swapped in one ton hangers and springs using the 3/4 ton mounting holes?
Old 01-25-2022, 12:16 PM   #33
LockDoc
LockDoc's Avatar
Thanks Chip, We are doing good. Pat had her right knee replaced a couple of months ago and is doing great.
Yup, 8ft bed C30 dually.... Thanks Dale.
No, it wouldn't be a direct swap because the frames are different. The C&C frames are straight in the back and the C20 frames have a kickout. I may end up having to narrow the front hangers a little too but I am going to try it this way first. I even thought about going to 1 ton coils & trailing arms on it. I have some off of an ambulance.
LockDoc
Leon
Old 01-25-2022, 02:57 PM   #34
CG
BlahBlahBlah
So you would have had to space out the one ton stuff, interesting.
I had no idea they made trailing arms and coils in one tons.
Old 01-25-2022, 09:39 PM   #35
LockDoc
LockDoc's Avatar
No, the one ton C&C spring hanger brackets need to be made narrower, or new ones need to be made like I did for the rear. I narrowed those up by about 2 inches.
Also, they didn't have trailing arms and coils in any one tons. I was going to convert it to trailing arms and coils. I would have had to add a trailing arm cross member, C20 trailing arms, and weld coil spring pads on the rear end housing. The 1 ton coils I have I removed from the rear of a Chevy ambulance that had the heavy duty coils.
Sorry about the confusion....
LockDoc
Leon
Old 01-26-2022, 09:04 PM   #36
LockDoc
LockDoc's Avatar
Installed the 2003 Chevy engine and transmission this morning. It was originally a 4x4 so I had to source a 2WD transmission for it. I had an ad on CL to buy just the rear tail housing and yoke so I could switch it over. A guy called me and said he had a complete 2WD transmission that he would sell me about as cheap as I could buy the parts and switch mine over..... $500.00. Needless to say, I went and picked it up. I had to make a rear transmission mount because the 2003 mount was too tall. I used a stock TH350 transmission cross member for the rear trans mount. If I had dropped the center of the cross member I could have used the stock Allison rear mount but I think that would have made the engine angle too severe. This is why I installed the '72 big block frame brackets and mounts. (Now 68Gold/white has his answer too.) ..
LockDoc
Leon
Old 01-27-2022, 12:12 PM   #37
FL71C10
That's a beefy looking powertrain!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 01-27-2022, 01:11 PM   #38
LockDoc
LockDoc's Avatar
Yup, Work truck...... Chevy 8.1 496ci with an Allison 1000 5 speed overdrive transmission.
LockDoc
Leon
Old 01-27-2022, 02:50 PM   #39
Sounds like a great combo!
Old 01-27-2022, 11:35 PM   #40
El Dorado Jim
nice project
El Dorado Jim is offline   Reply With Quote
Old 01-27-2022, 11:42 PM   #41
LockDoc
LockDoc's Avatar
Originally Posted by El Dorado Jim View Post
nice project
Thanks guys. I am looking forward to driving it for sure.
LockDoc
Leon
Old 01-27-2022, 11:43 PM   #42
LockDoc
LockDoc's Avatar
Set the cab back on the frame today. I had to cut the low hump out and install a high hump. I have about an inch clearance from the transmission to the hump with the new body mounts. I am ready to set the bed back on but I need to do some cleanup, priming, and painting on the back of the cab and front of the bed before I do, and it's raining today. Bummer!
I will also need to widen the in bed wheel tubs but I want to see exactly how much I am going to need first.
EDIT: I can't believe I forgot to take a picture of the actual cab sitting on the frame. I thought I took one but it isn't on my camera card so not sure what happened. Oh well, you can see it when I get the bed on.....
LockDoc
Leon
Old 01-28-2022, 07:40 AM   #43
Ol Blue K20
You're moving right along, great progress...
Dale
Old 01-28-2022, 08:48 AM   #44
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work Leon! Are the bell housing bolts pretty tight at the firewall. It looks like it might be real fun to swap a trans in? Probably still better than the newer trucks though.
Ryan
1969 Chevy milk truck
Old 01-28-2022, 03:09 PM   #45
68Gold/white
Leon, Are those rear tires, Keepers???
They look like you are planning to attach a plow to the trailer ball, and turn some ground...LOL!!!
Old 01-28-2022, 04:04 PM   #46
fatbass
fatbass's Avatar
Subscribed. Real work truck.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 01-29-2022, 12:37 AM   #47
LockDoc
LockDoc's Avatar
Thanks Dale.
I will double check in the morning Ryan. I forgot to look today.
Pulling truck....... They will all be new when I get ready to start driving it.....
Thanks.
LockDoc
Leon
Old 01-29-2022, 10:40 PM   #48
LockDoc
LockDoc's Avatar
My pictures came up missing when I set the cab back on (or I forgot to take any) So here is the cab AND the bed back on the frame....
I won't have to widen the rear wheel tubs all that much. I will do that in the next couple of days. Everything fit really well. Progress!
EDIT: I removed the cheapie hitch after I took these pictures.
LockDoc
Leon
Old 01-30-2022, 12:40 AM   #49
rickcdewitt
rickcdewitt's Avatar
That looks awesome. What is the rear axle out of? Ratio?
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 01-30-2022, 01:01 AM   #50
LockDoc
LockDoc's Avatar
Thanks,
Rear axle is an Eaton HO72, 5.14 ratio, out of a '67 Chevy Cab & Chassis truck.
LockDoc
Leon
