#601 |
![]() Join Date: Jul 2014
Re: The 60-66 "PAYING IT FORWARD" thread!
PM me your info.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
#602 |
All from a 1964 C10:
* Used master cylinder - Single reservoir original type * Approximately 2 year old used master cylinder - Single reservoir original type * Used OEM track bar * Radiator. Has leak * Left and right doors - Gone. * Monroe 33033 shocks. About 18 months old.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
#603 |
![]() Join Date: Mar 2006
Parts from a 1962 C10 - located in Pittsburgh, PA - pick up or pay shipping and they are yours:
Front spindles & brake drums - 1 spindle almost new, new bearings on both sides Behind seat fuel tank - tank is solid but does have some interior surface rust Front chrome bumper - decent chrome but has a bit of a "twist" Brake & clutch hydraulic master cylinder - surface rust but looks ok inside - 2 yrs old Steering shaft complete with center joint - need rag joint Manual steering box - a little loose Come get what you need - I hate to throw things away - prefer someone uses them |
#604 |
Gentlemen, you give me hope for this world. You guys rock. I'll hop in cuz lately, theyre taking up space and i need it to work. What i currently have is:
-Original gas tank out of a 65 with sender, everything works -Original rear springs -Heater box with lines -Steering column out of a 64 (3 on the tree) -Two 6 lugs wheels with horrid tires, no idea what year theyre off of When I dig deeper this weekend, ill see what else I have. Currently located in El Paso TX, but i will ship. Side note, im looking for doors, and a cab someone is willing to chop up a little bit, need the cowl vents from top to bottom. If you want pics, just ask ill happily send them |
#605 | |
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop ![]() 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
#606 |
* Used master cylinder - Single reservoir original type * Approximately 2 year old used master cylinder - Single reservoir original type * Used OEM track bar * Radiator. Has leak * Monroe 33033 shocks. About 18 months old. * Book: "Rochester Carburetors", by Doug Roe and Bill Fisher
#607 |
I'm interested in that Rochester manual. I've got a 4GC that I've been needing to put back together. My memory of the disassembly has faded.
#608 |
Getting rid of a wheel. I don’t know anything about it other than it was in my spare tire rack when I bought the truck. It is not a split rim and it will not fit on disk breaks. It has some surface rust. If nobody takes it it’s going into the trash. I am not willing to ship it. If they look like they are too far gone let me know.
#609 | |
![]() Join Date: Aug 2010
If 15", I'll let the next guy have it as I'm presently flush with those. PM coming. |
#610 | |
My truck ain't dead, it just smells funny. |
#611 | |
#612 |
![]() Join Date: Jul 2015
SOLD.....
Speakers for almost anything. RetroSound. You pay shipping, maybe $12-15
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 08-24-2022 at 03:56 PM. |
#613 |
![]() Join Date: Sep 2011
Ill take them.
Never drive faster than your Guardian Angel can fly Larry |
#614 |
Ok. Pm your info.
1963 C20, small window, long bed 292, 4-speed |
#615 |
Speakers arrived. Money sent. Thank you
#616 |
![]() Join Date: Aug 2005
1965 283 complete minus frame mounts. "ran when parked" Not seized, has not torn into as I have no interest in it. Have the exhaust manifolds that go with it. Bring a tire to set it on and I'll hoist it up. Includes a complete sm 420 trans. Also have a 89 s10 T5 trans with a .86 overdrive with electric speedo. I think its a world class but would need to double check.
Good T5 info here https://lugnutz65chevystepside.weebl...-page.htmlMust pick up in southern Utah |
#617 | |
What city are you in? Edit: I may be able to drive out to you Sunday.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 08-25-2022 at 01:22 AM. |
#618 |
283 still available
#619 | |
#620 |
Master cylinder, only used a couple of days.
Just pay shipping, probably about $20.
#621 |
Active Member
![]() Join Date: Nov 2019
Interested. What’s the application and or brand and p/n?
#622 |
I think it’s this one: https://www.globalindustrial.com/p/r...e-reman-101329
That’s the number on the sticker. I was converting my 63 to disc brakes and needed a new master cylinder. This one wouldn’t work because the length of my brake pushrod wasn’t right.
#623 |
Factory heating/air conditioning system from a 1964 K20. Pretty much complete.
I removed it from the truck this past spring. An R-12 fitting failed some years back and the system leaked down. Heat still worked and I didn't really need AC in Pennsylvania. But I ended up replacing the entire system with a new Old Air Products system in April just because. The system as you see it in the pics is complete except for (1) the original R-12 flexible lines which I threw out some years ago. (2) the dash defrost fittings which I am using. I hate to junk it as most of the parts are good and some are very hard to find. But crating it up and shipping it is something I'm really not interested in doing, so shipping is a no. I will load the skid in your pickup or van. I am near Altoona Pennsylvania. I don't know how to size the image properly on this forum. PM me and I can send additional pics. ![]()
1964 K20 big window factory a/c( bought in 1992) Last edited by printing724; 06-14-2023 at 04:39 PM. Reason: trying to add pics. |
#624 | |
![]() Join Date: Apr 2009
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
#625 |
I would like to take it off your hands. I will be in your area the week of July 4th if those responding ahead of me pass on it. Will send a PM as well.
