Old 01-27-2022, 02:33 PM   #1
Puglia10
1979 3+3 GMC Dually
Hey everyone. I was on here a while back with a 1980 c10, but the project was too big for me while I was in school and working.
Finally picked up a truck I’ve been trying to find for a long time. It’s a 1979 crew cab dually. It’s rust free from California (I’m in MA, everything is rusty) and it seems to be all or mostly original and unmolested.
My plans are pretty simple, being such a nice example I want to leave it mostly alone but clean it up (especially interior), fix the dents, AC, paint the fender etc. then lower it (maybe 6/8?) and put it on 22” semi wheels.
I’ll have some questions for sure, but figured it should go in the project section.
My first question is how to tell what’s original, what the truck came with, paint code, etc. can that all be accessed somewhere with the VIN? I want to check my rear end gears, make sure I get the right grille, etc. and find out any cool info - like what makes it a camper special and that kind of stuff.
On to the pics:
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 01-27-2022, 02:38 PM   #2
Puglia10
Re: 1979 3+3 GMC Dually
Ugh sorry some of them posted sideways. Not sure why lol
1979 c30 3+3 dually
1946 GMC
Old 01-29-2022, 06:33 AM   #3
Corts60
Just here to tinker
Corts60's Avatar
Beautiful! There should be a spid label in your glovebox or on the fender well under the hood that will label all options. If that is missing, then it will be hard to know all the original options. But You might be able to give the GM heritage center your VIN and maybe they can get you a build sheet.
Old 01-31-2022, 06:03 PM   #4
SCOTI
SCOTI's Avatar
Looks like a decent start. Check the glove box for the SPID info. The label was there for my dually.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2022, 02:11 PM   #5
Puglia10
Dang, no label in the glovebox. Ill see what I can find from the VIN. I'll need the paint code at least to paint the new fender.
What're you guys doing for highway speeds? I assume they all came with 4:10s? 60MPH is pretty high RPM....not great for around here when 80 is normal cruising speed. If I change the gears will it get out of its own way around town?
Ordered some interior parts I needed from Brothers. Of course the dash pad I really need is on backorder.
Next phone call will be for semi wheels and a drop....anyone to stay away from? I've heard good things about lowboy so far.
1979 c30 3+3 dually
1946 GMC
Old 02-01-2022, 03:40 PM   #6
Puglia10
does anyone sell the fender trim? havent seen it online anywhere.
1979 c30 3+3 dually
1946 GMC
Old 02-01-2022, 04:14 PM   #7
SCOTI
SCOTI's Avatar
Lowboy is mainly bagged set-ups. I asked if he did an arm set-up that would work w/coils & he said "no, but it might be worth looking in to...". Not sure it is on his 'to-do' list but I'm betting no.
3" spindles & drop coil up front get's your 6" drop. The front x-member gusset bars will be creeping in close to the tarmac on decent size dips on the road w/the stock stuff that low.
Flip kit for the rear is 8" (+/- depending on the spring-pack count). At 8" drop you'll be bumpin' the bottom side of the bed floor w/the differential (they're porky).
Nothing should hang below the rails @ 6/8. They'll high center around town.
I think 4.10's is the most common for the HD rears. Mine does around 2800-3k @ 65-70 w/31.7" rear tires. Some guys will do 3.73's & there are also 3.54's available but like you mentioned it could impact the ability to get a load moving. I search C-list weekly for a 4l80e.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2022, 04:39 PM   #8
kwmech
They came with 3.73, 4.10 or 4.56. Tires came as a 215/75r-16 or a 235/85r-16. 235s are preferred as they are 31.5'' tall. Lowered dually in MA will be fun in the winter
kwmech is online now   Reply With Quote
Old 02-03-2022, 11:28 AM   #9
Puglia10
I called them yesterday and the guy Eric was really helpful. I ended up ordering a 5/7" kit from them to avoid having to cut into the bed, and our new england roads SUCK so he suggested thats a good height for looks and still keeping some driveability around here.
He also set me up with the semi wheels so I'm real excited to get this stuff in and transform this truck!
I definitely need to decide on something to make it more highway speed friendly. Whats needed on the 4l80e swap? I would assume swapping gears is easier but maybe not?
1979 c30 3+3 dually
1946 GMC
Old 02-03-2022, 11:30 AM   #10
Puglia10
The tires on there now are 29.3" tall and thats right about what the 22" setup will be at also (225/75 R16 and 265/35 R22 ) Hopefully that doesnt hurt me too much. I gotta get the RPMs down on the highway.
Lol, this truck is too nice underneath (and 2wd) to be driving around here in the salt and snow....itll be a 3 season truck only. Ill keep my f250 for winter duty.
1979 c30 3+3 dually
1946 GMC
Old 02-03-2022, 12:18 PM   #11
SCOTI
SCOTI's Avatar
Taller tires = rpm drop just like putting in different gears.
225/75-16 @ 29.3" w/4.10's 1:1 final drive gear @ 65mph = 3056rpm
225/75-16 w/3.73's & th400 1:1 final drive gear @ 65mph = 2780
265/35-22 w/4.10's & th400 1:1 final drive gear @ 65mph = 3056
265/40-22 @ 30.3" w/4.10's 1:1 final drive gear @ 65mph = 2955rpm
265/40-22 w/3.73's & th400 1:1 final drive gear @ 65mph = 2689
265/45-22 @ 31.3" w/4.10's 1:1 final drive gear @ 65mph = 2861rpm
265/45-22 w/3.73's & th400 1:1 final drive gear @ 65mph = 2603
29.3" tire w/4.10's & 4l80e .75 final driver gear @ 65mph = 2292rpm
29.3" tire w/3.73's & 4l80e .75 final driver gear @ 65mph = 2085
30.3" tire w/4.10's & 4l80e .75 final driver gear @ 65mph = 2216rpm
30.3" tire w/3.73's & 4l80e .75 final driver gear @ 65mph = 2016
31.3" tire w/4.10's & 4l80e .75 final driver gear @ 65mph = 2146rpm
31.3" tire w/3.73's & 4l80e .75 final driver gear @ 65mph = 1952
A Gear Vendors OD set-up would be similar gearing behind a Th400 @ .78 vs .75 final drive ratio (the GV would be slightly higher rpm's vs the 4l80e).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-04-2022, 07:10 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
I daily drove my swb with T400 and gear vendors for the better part of a decade. Loved that combo.
Also your dark brown is most likely cordovan brown. Light tan might be Sante fe tan.
Old 02-04-2022, 07:49 PM   #13
SCOTI
SCOTI's Avatar
I looked into one for mine. The TH400 was rebuilt prior to my ownership but works fine & has a firm shift. I figured the GVOD would keep things simple. But, the way my carrier bearing & exhaust (3" dual w/H-pipe) is laid out would likely require re-working them to put one in. Plus, w/it being aggressively lowered, the actual GV sump would be near mid-cab which is around the most vulnerable spot in the length of the truck. When your ~5" off the ground w/a ~20' frame length, that's an expensive ouch if it tags anything.
For the cost of each, I'd do a 4l80e in a CC lowered dually.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-04-2022, 08:33 PM   #14
Corts60
Just here to tinker
Corts60's Avatar
Haha, well when you put it that way, I agree with you 100%!
Old 02-04-2022, 09:51 PM   #15
Willowrun
Willowrun's Avatar
I don't think I saw it mentioned, and from what I see of your engine pic it looks to be a big block, but could you confirm what your truck has for a motor?
Willowrun is online now   Reply With Quote
Old 02-07-2022, 01:00 PM   #16
Puglia10
yes, 454
1979 c30 3+3 dually
1946 GMC
Old 07-26-2024, 03:19 PM   #17
Puglia10
I haven’t been on here in a while so I have some updates.
I finished this truck and it was awesome.
Then my garage burnt down and took the truck with it. Not awesome.
So today I bought another crew cab dually. Here are pics:
1979 c30 3+3 dually
1946 GMC
Old 07-26-2024, 04:57 PM   #18
SCOTI
SCOTI's Avatar
Oh man!! That sucks in a big way. I hope the new one runs & has 'as good' of bones as the one you lost.
Same game plan or making changes?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-29-2024, 01:44 AM   #19
kitsbeach
kitsbeach's Avatar
Geez that sucks about the fire. New one looks pretty sweet tho.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 07-30-2024, 08:37 AM   #20
Android04
Android04's Avatar
That's devastating but glad you got another one in the works!
Android04 is offline   Reply With Quote
Old 07-30-2024, 10:49 AM   #21
Puglia10
Condition wise its actually nicer, but I do prefer the two tone and round headlights. I just couldnt pass up on this white one.
Pretty much the same plan...Im going to see if I can save the 22" alcoas. Same drop. My plan was to 6.0/4l80e but this 454 runs so good I'm having second thoughts. It does need some sort of overdrive though.
I'm going to see if the Gearvendors OD from the brown truck can be saved.
1979 c30 3+3 dually
1946 GMC
Old 02-13-2026, 02:53 PM   #22
Puglia10
Haven’t been here in a while. My last message is funny since I said it runs good lol. 454 went boom, so 6.0 swap is almost done.
I also can’t fall in love with the front end so a 73-80 nose is on the way, then I’ll find a 73/74 grille.
1979 c30 3+3 dually
1946 GMC
Old 02-13-2026, 04:00 PM   #23
SCOTI
SCOTI's Avatar
Glad to see you're still at it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-17-2026, 10:47 AM   #24
Puglia10
If anyone’s done a round eye swap and has any advice feel free to chime in!
I’m collecting parts now. I got inner and outer fenders, a radiator support, hood, grill, headlights and bezels.
I think I need wiper linkage, wiring harness (or do I modify mine?) and a front bumper. With brackets I assume?
I wonder if I need to bolt it all up before paint or am I safe to paint then install?
Any other snags or parts I should be aware of?
1979 c30 3+3 dually
1946 GMC
Old 02-17-2026, 11:34 AM   #25
SCOTI
SCOTI's Avatar
I would bolt everything together first. A 'dry' run is always smart wrenching to sort out the unforeseen issues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
