02-11-2022, 10:14 PM | #1 |
One Piece Floor - Any recent updates on Quality or Installation?
I've got a customer truck that can benefit from one of these floors. Has anyone done one recently? This is going in a 1960. LMC has the 1960-62 in stock.
I've done one in a 1968 C10 and it was pretty decent quality. Not perfect but acceptable. Nice clean new sheet metal is great. Just looking for any recent feedback. Not much info on them in the 1960-66 category.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
02-16-2022, 07:36 AM | #2 |
Re: One Piece Floor - Any recent updates on Quality or Installation?
i have a cab floor for my 66 from lmc. i haven't installed it yet so i cant comment on fitment. i hope other chime in to help us out.
02-16-2022, 10:39 PM | #3 |
Well... the new floor has been ordered from gmcpauls. It says it is made specifically for them. $200ish more expensive than anyone else but I'm good with supporting a family business. I'm terrible with documenting pics but I'll need to for this customer. Will share feedback once I have some. Looking at about 2 weeks for delivery of the floor.
02-17-2022, 07:39 PM | #4 | |
Check The Champ, Demonstrator
GMC PAULS wood dimensions must be the most shared link on the internet.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
02-17-2022, 08:53 PM | #5 |
I've been getting the cab ready. New mounts installed. Interior stripped. Double checking the fit of the doors before I brace the cab.
03-01-2022, 09:40 PM | #6 |
The floor has arrived. Ordered thru GMC Pauls. The box indicates it is a Dynacorn floor. It may be a decal placed over the actual manufacturer.
I built a dolly for transporting the cab from our main shop to the shop at my house. The paint booth has way more light in it. I think I may be getting older but that sure is nice! The bracing is all removable. Tomorrow I'll try to get the old floor out and update everyone with some pictures. I'm going to carefully cut out the old rockers first... so I can see how they fit before I replace the floor. The new ones came from GMC Pauls in a key parts box. They seem to be very nice. There's going to be lots of rust to treat on the cab back wall. I'm not looking forward to that. Lots of grinding, wire brushing, cutting and welding. Looking forward to giving this guy a much better cab. Reportedly it came from the southwest. Lots of fine dirt, sand and RUST.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com Last edited by kxmotox247; 03-01-2022 at 09:47 PM. |
03-02-2022, 08:04 AM | #7 |
Top notch work as always. Very nice job on the bracing.
03-02-2022, 10:32 PM | #8 |
Thank you OL SKOOL. I try. Like everyone else I try to learn and up my game each time to make things easier in the future.
Things took longer today than I thought. I was able to get both rockers out. I could have crudely hacked them out but I wanted to remove them carefully to do a test fit of the new rockers using the old floor. I'll attach a couple of pics. I believe these are key parts rockers and were purchased thru GMC Pauls. They feel a bit lightweight compared to the 67-72 Key Parts rockers. They also have the little gold Made in Taiwan stickers which I hadn't seen before on Key Parts stuff so now I'm suspecting they could be some other stampings. Holding confidence that GMC Pauls is selling the best regardless of manufacturer. They have that reputation. So the report is that the rears of the rockers fit great. The fronts are a little off and will require a bit of massaging to fit properly. Not a huge deal. The weather strip seal appears to be a little further away from the OE floor (closer to the door). We'll see what it looks like with the new floor. I really just wanted to see what these relationships were like with the OE floor.
03-03-2022, 08:06 PM | #9 |
Not good news with the floor. Box had been relabeled by someone as a 1960-1962. We opened it up and it's for a 1963-1966. The only difference that I see is the mounting location for the forward cab mounts. The spot of green tape is where the front cab mount bolt should be.
I've contacted GMC Pauls for advice on what to do. I'm sure I can modify it to work... but not really wanting to do that. Plenty to keep me moving in the meantime though.
03-03-2022, 08:12 PM | #10 |
The old floor is out. Even the cab supports that appeared to be okay were rotten on the bottom. I'm glad we're going to be solid now. Lots of reference measurements made in relation to the inner/outer rocker shelf and also the distance between pillars. I reverified the measurements after removing the floor and there was no change.
Next up will be replacing the kick panels, cab corners and the flange that runs along the back wall. Will be cleaning and treating all of the rust that I can get to. I'm not a believer in POR15. It's certainly better than nothing but I may just clean and use a good epoxy primer. Truthfully either should be adequate for the life that I anticipate this truck to have.
03-03-2022, 10:20 PM | #11 |
Odd that the box says it comes with a hump hole, as opposed to hump not included, lol.
03-06-2022, 10:33 AM | #12 |
Starting this process on my 64 in a couple of weeks. Can’t wait to see how yours turns out!
03-06-2022, 10:05 PM | #13 |
GMCpauls has ordered us a new floor. They're going to send a truck to pick up the incorrect one. So that's good news.
So a couple of photos. The rusty flange on the back side of the cab needs fixed before I put the new floor in. I started cleaning as much of the sheet metal as possible including the cab corners. I gotta get back to decent metal. I wish the repro corners wrapped around the back a little further. May use some of this floor and the beads to fix the flange. We'll see.
03-08-2022, 12:13 AM | #14 |
classic parts of america now sells the lower rear patch panels for cab back wall.just thought i would pass it along.i will be watching as you progress on the metal work.
03-08-2022, 09:14 AM | #15 |
Wow. That's great. I wish I would have seen this earlier. If I can't salvage some good metal to use then I will go that route.
03-11-2022, 10:47 AM | #16 |
New-ish metal repurposed for the back wall flange. Not perfect but will certainly do this cab some good. I epoxied the bare metal to get it sealed as soon as possible. The customer wants POR15 on the inside though. I surmise that the rear wall must scoop up rain water and moisture while going down the road. That's the only way I see that much rust occurring. Even across the areas where the rust hadn't broken through was deeply pitted.
Waiting on the new floor, inner roof patch, and air vent patch.
03-11-2022, 11:04 PM | #17 |
Door pillars on passenger side fixed today. Kick panels cut open to assess the inside for rust.
03-22-2022, 09:44 PM | #18 |
Nice work. I wish they had the full floor when I did my truck would have saved me a lot of work.
03-25-2022, 09:05 PM | #19 |
Quick update. The second floor arrived. This time the box was labeled correctly as a 1960-1962 Floor. However the second replacement floor is actually a 1963-1966.
I contacted gmcpauls and the problem was escalated thru their vendor(s). What they found is that the last influx of floors in 3 separate warehouses are all improperly marked. This leaves me with no choice but to modify the one I have. I will post some updates soon.
03-25-2022, 09:22 PM | #20 |
Man, that's a bummer. Sounds like someone is going to get a butt chewing in the packing department
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-25-2022, 09:32 PM | #21 |
Isn't it? Huge mistake. Sounds like Dynacorn ordered 1960-1962 floors but all of them were built wrong. Good thing I saved the floor cups from the old floor.
03-25-2022, 09:51 PM | #22 |
Yeah, definitely good that you saved them. I wonder if a bunch of 63-66 boxes are floating around with the 60-62 floors
03-25-2022, 09:59 PM | #23 | |
We joked at work that a fellow could make a few bucks by offering a retrofit kit to convert them. I got the impression that there were cargo containers full of the incorrect ones. The floor looks like a nice piece otherwise.
09-29-2022, 10:05 PM | #24 |
Sorry. Significant delays while we reprioritized some other projects this Spring & Summer. I jumped back in first week of September. Decided that the best time to put this over the windshield patch is right now... with no floor.
09-29-2022, 10:18 PM | #25 |
Primed the roof. Stripping the rest of the cab. I feel like a more efficient use of time and money would have been to hire a blaster. Cost is roughly $800 but would have significantly saved on labor and removed more rust.
I hate that these pictures want to come out sideways.
