#26 |
Re: Mark's 51 Build
You could make a cardboard pattern and hang it in place with magnets or duct tape. Come up with what looks good whether it is 1, 2 or 3 pieces. Then fab it up out of 16 or 18ga cold rolled sheet. Make it a little big so you can finish the edges if you like.
#27 |
Re: Mark's 51 Build
Use some 18 gauge metal and make an apron. If I remember, there are several bolts located under the grill you can use to attach it with.
Also, I liked your steering wheel center idea so much, I put it on mine. Thanks
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#28 |
Re: Mark's 51 Build
I was asked about frame pictures and wheel spacing.
I really regret to say the best photo shot of the frame was posted The wheels are just 15" American racing wheels. I went to a local wheel shop with measurements from mounting surface to fender lip and he ordered based on that. I really don't have record of the wheel specifications. It was dumb of me not to document more of what I did, however the dakota chassis does not garner much interest. |
#29 |
Re: Mark's 51 Build
I'm starting another AD truck. This will also use a Dakota chassis. I want to use a 292 engine with standard transmission. What I'm hoping for some feedback on is a clutch and brake pedal assembly solution. Has anybody reworked a clutch/brake under dash pedal assembly into one of these trucks? Planning on a hydraulic clutch. Thanks.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
