Old 02-02-2022, 09:26 AM   #2076
lower50's
lower50's's Avatar
Re: My 50 roadster pickup build
Originally Posted by oldman3 View Post
Hey Bob, what makes me mad, is all the parts are new, from good sources, I guess someone has to get the bad ones...Jim
Ya I have noticed for a lot of things, even if you buy a good one it is still crap.
My example I use is my toaster it is a good Tfal I have had for 25 years gets used multiple times a day and works perfect. If I was to go get a new good expensive toaster I don't think it will last this long. Sorry for the rant.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-02-2022, 11:00 AM   #2077
oldman3
oldman3's Avatar
No rant, it's the way things have become. Everything seems to be good now, weather here has stopped Brendon from tuning with his laptop, hopefully next week...Jim
oldman3 is offline   Reply With Quote
Old 02-21-2022, 06:00 PM   #2078
oldman3
oldman3's Avatar
Well time for an update, and still having issues. After weather final cleared up, Brendan came over and hooked up laptop and off we went. Only a few miles down the road, he said turn around and go home.
The computor speed was jumping from 60 to 50, 60 to 40, all over the place. There was nothing he could do until this was corrected. We talked about the speed sensor, and he told me to purchase an AC Delco speed sensor and check it again.
He helped me with my OBDII diagnostic scanner, thru bluetooth to my phone, so I had a gauge and graph to show what the computor was seeing. This thing can do so much more, will have to play with it later.
Installed new speed sensor, took it for a drive, the same problem. After talking with Brendan we checked the alignment of the reluctor wheel on transmission shaft and the speed sensor. This is where we found the problem. The reman. transmission I bought wasn't done very good. We could see 4 or 5 teeth badly broken, this was causing the fluctuation in the readings.
Today Mark and I removed the tail section from transmission and could see how bad the reluctor wheel is, so Mark heated the gear and removed from the shaft. I have another one ordered, but it woun't be here till Friday.
I'll post up some picture, in a minute...Jim
Old 02-21-2022, 06:19 PM   #2079
8man
Wow. That wasn't easy to find. Hope when you get the new one everything works great.
Keep the faith. The LS in my Cherokee has been great!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 02-21-2022, 06:30 PM   #2080
oldman3
oldman3's Avatar
Pic 1 Transmission tail section, hole in side for speed sensor.
Pic 2 The three speed sensors. Top one would not let trans. shift out of 1st gear. Middle one took care of shifting, but thought maybe it wasn't correct.
Bottom is the AC Delco. Turns out the middle and bottom were not the problem
Pic 3 I couldn't focus good enought on the reluctor wheel, but at the top you can see part of the tooth missing, along with 4 others. Also more damage on the other teeth.
Pic 4 The arrow head shows where the reluctor wheel (or gear) was installed on the shaft. Will get new one and install...Jim
Old 02-21-2022, 08:30 PM   #2081
oldman3
oldman3's Avatar
Thanks Robert, Mark and I both did a lot of checking on the internet,etc. Brendan was a big help...Jim
Old 02-21-2022, 08:36 PM   #2082
OutlawDrifter
Jim, once it's all sorted, the nonsense will be nothing but a laughing point.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 02-22-2022, 12:14 AM   #2083
oldman3
oldman3's Avatar
Outlaw, I agree. Like everything about the change. Just need to get this all sorted...Jim
Old 02-22-2022, 09:19 AM   #2084
youngrodder
youngrodder's Avatar
You'll get past these minor set backs Jim....
Your gaining. Keep at it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-22-2022, 10:23 AM   #2085
dsraven
good catch and at least the trans didn't have to come out. access actually looks pretty good from the pics. now, to find some decent parts.......
Old 02-22-2022, 11:27 AM   #2086
oldman3
oldman3's Avatar
Marc
Thanks Marc, hope this is the last...Jim
Thanks, new wheel is AC Delco, so I shold be OK...Jim
Old 02-23-2022, 11:04 AM   #2087
Indian113
Indian113's Avatar
Hang in there Jim. You will get all the bugs sorted out and will be having a great time soon!
Indian113 is offline   Reply With Quote
Old 02-23-2022, 11:38 AM   #2088
oldman3
oldman3's Avatar
Thanks Ray, I'm sure we will...Jim
Old 02-23-2022, 11:49 AM   #2089
Tempest67
Tempest67's Avatar
that is so frustrating, but I am sure it will get sorted out.
look forward to reading that you are driving the wheels off it.
Tempest67 is offline   Reply With Quote
Old 02-23-2022, 03:49 PM   #2090
oldman3
oldman3's Avatar
Thanks Tempest, yes as soon as it's tuned, I'll be driving it and putting miles on the new toy...Jim
Old 02-27-2022, 09:12 PM   #2091
oldman3
oldman3's Avatar
Little update. Received new reluctor wheel late Friday in the mail. Mark installed the new wheel on shaft and put everything back together on Saturday.
We hooked up my OBD11 scanner and checked the speed, was showing nice and smooth, no up and down like a hearbeat. Will have to wait a day or two before I can drive it. We had about 4" of sleet between Wed. and Thurs. so the drive is not good.
Pic 1 is the gauge on my phone, where we checked the speed.
Pic 2 and 3 is the driveway.
Later...Jim
Old 02-28-2022, 09:17 AM   #2092
youngrodder
Good....your gaining.
Marc
Old 02-28-2022, 10:42 AM   #2093
dsraven
love that red truck color. what year is that?
Old 02-28-2022, 11:15 AM   #2094
oldman3
oldman3's Avatar
Marc
Thanks...Jim
It's a 2020 Chevy Silverado that Mark drives...Jim
Old 03-02-2022, 05:30 PM   #2095
oldman3
oldman3's Avatar
Quick update, drive way all dry, so I took about a 30 mile drive today to check things out. What a difference, the new reluctor wheel made the computor happy. It stays at a steady 60 mph when I can hold the throttle correct. Trans is not shifting in and out of lock up torque converter. Cruise holds a steady 70 mph when on the 4 lane. Super happy with it. Still need to have Brendan hook up his lap-top, but good for now.
Heres a couple pics. Showing driving down the road. Second pic is of my phone hooked up to OBDII showing what the computor sees. Not clear, but rpm is 1254 at 59.7 mph.
Later Jim
Old 03-02-2022, 05:34 PM   #2096
8man
Very nice!
8man-aka Robert
Old 03-02-2022, 05:42 PM   #2097
OutlawDrifter
Just lumbering along! You might need a gear change, LS's don't lug very well. Their happy place is in the higher revs.
1991 Z/28, 6.0L/T56
Old 03-02-2022, 06:05 PM   #2098
Indian113
Indian113's Avatar
He is right about that! 3:55 to a 3:73 would put you right into the middle with that sweet spot. Also I had to put a B&M lockup controller in my S10 and it is adjustable so you can fine tune it. But that is all stuff you will get sorted out and it will be a Blast to DRIVE
Old 03-03-2022, 12:37 AM   #2099
oldman3
oldman3's Avatar
Very nice!
Thanks guys, you are correct. Already looking for new rear axle. Current axle housing only has a #2 case, can't change to a higher gear ratio...Jim
Old 03-03-2022, 03:06 AM   #2100
lower50's
lower50's's Avatar
Looks like you will be out terrorizing the neighbor hood very soon. Do they use salt on the road where you live? They use truck loads of it up here usually not washed off the road till mid April
1951 MG TD
