02-22-2022, 12:01 PM | #26 |
Re: Headlights don't work and it's not the dimmer swich.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
02-22-2022, 01:25 PM | #27 |
02-22-2022, 02:23 PM | #28 |
Not yet. I'm going to completely buy pass thr HD harness. If that doent fix it then idk. But like I said I've had this issue before the hd harness was ever installed. I would just spam the dimmer and they would come back on Which leads me to believe it's not the problem. But I'll test on it when it not -8F with 30 mph winds.
02-23-2022, 12:42 AM | #29 |
Pardon my ignorance , but what exactly are you referring to with the "HD Harness" ? Are you running HID headlights maybe ? Trying to wrap my mind around what your wiring setup is .
02-23-2022, 07:03 AM | #30 |
No that's a solid question. I'm running the stock bulbs. The HD harness adds relays and takes the load off the dimmer and headlight swich running prower straight from the battery.
02-23-2022, 07:55 PM | #31 |
So the headlight relay harness upgrade. Something like https://www.lmctruck.com/1967-72-che...dlight-harness
02-23-2022, 08:43 PM | #32 | |
02-23-2022, 08:47 PM | #33 |
Update. Got it fixed. No this sounds stupid and believe me it was the first thing I checked. But the fuse on the HD harness was bad. It didn't blow it just bad looked likea good fuse. Changed it and they work now. I feel so dumb now. Lol thanks everyone for helping me and my stupidity. But I was right it wasn't the dimmer. Lol
02-23-2022, 08:55 PM | #34 | |
02-23-2022, 09:05 PM | #35 |
20' Daredevil (Ret)
Glad you got it fixed! You're not the first one to be fooled by a fuse's appearance....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-23-2022, 09:26 PM | #36 |
Who Changed This?
I worked as a mechanic for many years, and learned to not believe a good looking fuse. It only takes a couple of hours for that lesson to stick.
02-23-2022, 09:52 PM | #37 | |
02-23-2022, 10:20 PM | #38 |
You are so right Steeveedee. If its one thing you learn in electrical is don't assume anything and check everything. In the old days I had a circuit breaker I could put inline to replace the fuse.
02-23-2022, 10:35 PM | #39 |
Yep. Been there. I had good fuses on a ‘67 mercury restoration. Continuity when checking the fuse. Fuse holder was corroded slightly and didn’t send power out of it.
Again the cheap light 12 volt tester will find it. Best $15 you will spend for electrical problems.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
02-23-2022, 11:05 PM | #40 |
I don't think the fuse actually blew. Mainly becuse like I said in the first post when the light whare working I switched to hi beam they whent out. Spamed the dimmer they came back on then hit it again then off. A blown fuse wouldn't of came back for one more round. I think the cheap fuse that was in it actually broke. It came out in peaces. Pulled just the plastic out first. Then one side of it then the other. If I have this happen again then I'll look deeper but for now I'm going to leave well enough alone.
02-23-2022, 11:13 PM | #41 |
A lot of junk china fuses are out there. When I go junk yarding I always buy some of the original GM fuses.
02-24-2022, 12:35 AM | #42 |
20' Daredevil (Ret)
We bought a new Honda Accord in 1979 and had it 4 years. Sometime in the early Eighties, it started acting up intermittently. You'd be driving normally and it would die, than before long everything was fine again. It had the old glass cartridge fuses, same as our trucks. Can't recall which circuit it was but one fuse was bad. It was very hard to see the fault, which was a hairline fracture of the filament. Most of the time the ends touched enough to make a connection. But once in awhile it would go open. Hard to pinpoint, easy to fix.
